Trailer Brake Controller Wiring Is TOO SHORT
Haley
Mt. Lebanon, PA
2019 Ford Ranger Lariat
Software Engineer (Dreaded)
I am super frustrated. I bought the oem controller from redarc directly. I've gotten everything done except for connecting the controller to the truck itself. What I can't do is get the dang wire's connected via butt connectors because the truck's pigtail wires are so SHORT! They don't extend at all into the footbed so I have be completely upside down with my head under the dash. It's just impossible to hold a butt connector on a wire and have the placement right while also holding a crimping tool and getting the pressure right. How have any of you done this? The only way I've seen to make it longer is to cut the entire "braid" of wires open but I don't know if that would make things better or worse...
Cabose-1
Eli
Student
Well it is a bit of a tight squeeze. I did what you did but with a soldering gun and shrink tubing. That was a tight fit but the solder melted right on. I also have the redarc controller.
2022 xlt fx2
2021Ranger
Barry
NJ
2021 Ranger
Just did mine a week ago and the blue wire on mine was also very short. It was a PIA but I managed to get a but connector on it..
EJH
Ed
Subarus, 2021 Ranger
2022 xlt fx2
Solder with shrink tube here also. Those Ford under dash wires were pretty short!
Cabose-1
Eli
Student
It's a tight spot, yoga is involved. I am 5, 8, 160 lbs. Old compression fractures on my back, growing arthritis, eyes can't see anymore, s*@# come to think of it, lucky I soldered correctly, it can be done. I twined or tried twisting wires together soldered and heat gunned all the shrink wrap at the same time.
Blue Streak
Larry
Mine is a 2019 XL STX package. When I did mine I remember cutting some tape to give me more wire. :like: I believe they had the wires taped to the main wiring harness. It was no big deal to do.
ljames
Larry
Phoenix, Arizona
jameselectronics.com
2020 Ranger 4x4 FX4, 2011 CRV,1998 Ford E250 super
contractor
you managed to turn 4 connections into 12.. not my idea of correct.
Reactions: EJH
Blue Streak
Larry
Actually you should only see 8 wires. 4 from the truck wiring harness & 4 from the brake controller. So there is still technically only 4 wires. I am not sure where you see 12.
EJH
Ed
12 new wire connections, 12 possible points of failure.
Each wire has the spade connector and two wire crimps to each end of the spade connector.
I suspect that is what ljames means.
Unless you purposely kick em their not gonna fail.
I've had those wires butt connected for 2 1/2 years now, and they haven't come apart yet.
Using a regular Tenkonsha Brake Control....wires are tucked under the dash.
