Tires with a 2.5" leveling kit
Sheepdog
2021 Ranger SuperCrew 4x2 XL
Retired police officer
I went with 255/75 17s with 2.5 level kit. No mods and have plenty of clearance at full lock
Just be advised, that whenever you increase the aspect ratio and keep the width the same, the tire's tread gets narrower.
So all things being equal, a 255/75R17 has a narrower tread than the OEM 255/65R17...
Cardfan
Scott
Illinois
2020 Ranger Lariat FX4
Manufacturing
Thanks for the replies on this thread so far. This is certainly uncharted territory for me still, so continued apologies for my "noobness." So I have found some wheels I really like, but they are 20's as opposed to the factory 18's my truck has (specifically 20x9, +18mm offset). It seems they should be a decent fit based on what I have gathered reading the forums, but what size tire would folks suggest assuming a 2.5" RC level kit and zero desire to cut/remove components?
Here are the wheels for what it is worth
https://www.tirerack.com/wheels/Whe...anger+4X4&autoYear=2020&autoModClar=Supercrew
TN Ranger
2020 Ford Ranger
Electricain
I have to disagree. I can post a pic tomorrow of the 2 tires sitting side by side. The new ones are actually a little bit wider than the OEM but they are MT not AT
Sheepdog
I said all things being equal- look up the specs on those two sizes in the same brand and model of tire...
egilbe
Earl
Somewhere between ME and AZ, depends on the season
2020 Ford Ranger Lariat with BAP, Tow and FX4
Semi-retired, lazy bum/tramp, formerly Sys admin in a toxic work environment
Why would that be? Tire width should be exactly the same. Tires aren't shaped like inverted pyramids
AdamHarris
Adam
Blue Oval City, TN
Collision Repair Instructor
Holy crap nobody better not dare argue with this guy, dispite the fact he’s wrong And FX4s don’t have OEM 255s it don’t matter!! He’s done ever kind of Motorsport there is..just wait..he’ll tell you all about it..Again.
OFC Ranger
Jack
ZR2
I believe 285/70/17 are the largest you can do without bar modifcation/removal. Even then only some brands will work.
All I can tell you is mine had Toyo OC AT2 in the above mentioned size with a 2.5" lift and my clearance was paper thin on the crash bars. Once I went down in offset (then ending up at 0+) I completely removed my bars.
All I can tell you is mine had Toyo OC AT2 in the above mentioned size with a 2.5" lift and my clearance was paper thin on the crash bars. Once I went to 0+ offset I completely remove my bars.
You got 285/70-17 on WITHOUT bar modification/removal? I had to remove all of my bars, tire air dams, and zip tie pulled back the felt linings to completely clear my setup...
OFC Ranger
Jack
ZR2
Yes, my dealership had installed 285/70 and a 2.5" lift before I came along and purchased it. Here is the photo from March 2020 shortly after I brought it home and de-badged it.
I see...it's likely your offset were not messed with as you're on stock wheels...
OFC Ranger
Jack
ZR2
Oh yea, any movement to negate offset would have put me into the bars. It was very very thin clearance with that Toyo selection. Some 285's won't work at all because no manufacturer has the same exact 285 spec.
When I installed 2" spacers the bars came out as that moved me to +5, then I got the RTR wheels which put me at 0+
Sheepdog
Why did you install wheel spacers?
Sheepdog
Because tire sidewalls are not straight lines- they bulge, and the tire's size is based upon the widest part of that bulge, not the tread width. The taller the aspect ratio, the longer that inwards slope from the fattest part of the casing towards the tread, thus the narrower the tread, all things being equal.
