The time changed to military time,how?
2021Ranger
Barry
NJ
2021 Ranger
So got in my ranger this morning and for some reason my auto up/down window stoped working. It does go up and down but with out the auto function.. Hummmm then I noticed that the time changed to military time! So I went into setting and switched it back. Both were good yesterday. Anyone?
Given that your auto window function quit, I'd vote for a failing battery as well. When I replaced my battery I had to reset the auto up/down function.
Radioman
Kent
Roseville, CA
This
ok so how do you reset the auto up/down function?
It's in the owners manual - I always have to look it up - Page 79 on my version:
Resetting the Memory of the
Electric Windows - Vehicle with
One Touch Up/Down on Driver
Side only
Note: The bounce back feature remains
turned off until you reset the memory.
In the event of a flat battery or after the
battery is disconnected from the vehicle,
you must reset the memory for the driver
window.
1. Open the window and then try to close
it using the one-touch feature.
2. Lift and hold the switch to the second
action point until you fully close the
window.
3. Lift and hold the switch for more than
two seconds and release.
4. Open the window using the first action
point and try to close it automatically
using the second action point.
5. If the window does not open or close
automatically when you press the
switch or lift it to the second action
point, repeat the procedure.
Safety Mode
Note: The anti-trap function is not active
during this procedure.
If the system detects a malfunction, it
enters a safety mode. The windows move
a little at a time and then stop again. Close
the windows by pressing the switch again
when the windows stop moving.
Contact an authorized dealer.
Bounce-Back
The window automatically stops and
reverses some distance if it detects an
obstacle when closing.
Resetting the Bounce-Back Feature
Note: The bounce-back feature remains
If you disconnect the battery, you must
reset the bounce-back memory separately
for each window.
1. Lift and hold the switch until you fully
close the window.
2. Release the switch.
3. Lift the switch again for one second.
4. Press and hold the switch until you fully
close the window.
5. Release the switch.
6. Lift and hold the switch until you fully
close the window.
7. Open the window and then try to close
it automatically.
8. Reset and repeat the procedure if the
window does not close automatically.
Radioman
Kent
Roseville, CA
for each window.
close the window.
close the window.
close the window.
it automatically.
Edit:
Rob @RedlandRanger beat me to it...
