Tail Gate Dampener
geophb
Mechanical Engineer
Cap off/seal the cab vents in the rear and it will blow your mind how hard it is to slam the doors. Assuming the rest of the door are closed and windows closed.
Bproctor
Bproctor
Bruce
Hickory, NC
2019 Ford Ranger Lariat 2WD
NC National Guard
I assume you're talking about the ones under the seats. What did you use to do this? Tape?
geophb
Mechanical Engineer
They are behind the rear seats. Just look at the back of the cab if you google cab and chassis pickup.
I just remember doing it on an old regular cab pickup and it was almost impossible to close the doors, had to open them back up some. I bet cab volume size has a big effect on it, as its an air pressure thing.
Can use hamburgers as a door cushion...cheeseburgers work better.?
Bacon...Don't forget the bacon! lol
Animal Style Doubles from In and Out. Ditch the fries...
When I moved out here one of my friends turned me on to those. I never eat fast food but these I'll make an exception for!
Reactions: FoD
TexasTruck
Central Texas
2019 Ford Ranger XLT CC
In my forum travels over the years, I've read that blocking those cab vents might not be a very good idea - air bags. I hope they are never needed but when they are, the displaced air needs to go somewhere real fast and that's out those cab vents....
Deleted member 1634
There's a number of reasons to not block those vents, airbags being the most severe. HVAC being one of the more mild and everyday reasons. Any air you pump into the cab needs to displace/replace the air already there. So the HVAC system will have to work that much harder to essentially compress the cabin air and create a positive pressure state inside, possibly prematurely burning out the blowers in the process.
Jon Olivier
Jon
Bishop, CA
2019 XLT 4x4 - Hot Pepper Red, 302A, Sport Appearance, FX4, Tow Package,
IT Specialist - CA Dept of Transportation
I recently moved, and after having an In-N-Out on practically every street corner, I now have to drive 3 hours to get to one. Ugh!
geophb
Mechanical Engineer
First off, I was just jokin around. :) Just thought I should point it out. :thumbsup:
The vents are there solely to make it easier to close the doors, and ofcourse airflow for the hvac as mentioned. I would leave them open because its incredibly difficult to close doors with them sealed, made that mistake before.
It would have zero effect on the deployment of the airbags. Airbags explode so fast that the amount of air needed to displace in that time interval is faster than the vent could support even 100% operational, mainly due to location. (i.e. by the time the pressure wave gets there the airbag would be already open)
Doctorfong
Wayne
Fresno, CA
2019 Ford Ranger STX/FX4 (Wife's Car 2017 Fiat 500 Abarth)
Sales
My wife is just as guilty of the same thing. Her car does require a heavier hand though.
Spence's bumper sticker
Mesa, AZ
'20 Ranger Lariat FX4, '17 Edge Sport
Security Analyst + USN
I put dynamat in my doors. They still get slammed by everyone who rides with me but the "thud" is a much more pleasing tone now.
Did you happen to start a thread on this, or take pictures? I'd be interested in this mod.
geophb
Mechanical Engineer
i dont think you were joking around, i think you re-thought your comments after the backlash.
about the airbag though, nope, the airbag wont be held back in any way, it's an explosion thats going to do what its meant to do. if the vents are plugged, then the secondary damage occurs from that rapid explosion...such as other windows blowing out from the pressure wave....now who cares right?...your air bag already deployed, your cars fucked up anyways....but your ears....can you handle them blowing out?nope....i dont want to take the chance.
those vents are NOT there solely to make it easier to close the doors
There won't be enough pressure build up from the displaced air of an airbag to blow anything out.
Worst case is it leaks past door seals, if any pressure was going to build.
dmeyer302
Daniel
Carthage, MO
2016 Odyssey, 2021 F-150
Mechanical Engineer
