SVC Offroad Leveling Spring Perch Collars
rooster
BOS
STX FX4 SuperCrew
engineering systems admin
Is the alignment back to factory specs or are there modified specs specific for these collars?
rooster
BOS
STX FX4 SuperCrew
James Martincic
Jimmy
Pittsburgh pa
2019 ranger xlt, 2005 Saleen mustang, 2019 ram 2500
Does any body have a pic of their ranger with A 3” level with 165 70 18 tires
Would really like to see this set up thanks
Arch Stanton
Reno Nevada
2019 Ford Ranger XLT FX4 4x4 Ingot Silver 301A
V.P. of Research and Development; Telemetry and Guidance Testing Facility at Aerodytech Corporation, Reno, Nevada
Had the leveling collars installed today and got exactly 2" of lift as advertised.
FYI: Front measurement from ground to wheel well is now 37 5/8" and rear is 38 5/8". Running board front measurement to ground is 16" and rear is 16 1/4". Which means anything more than a 2 1/2" front lift puts your running boards running downhill towards the rear of the truck; meaning not level. Having equal front and rear wheel well measurements is not level, it means front sits higher.
Levcrowley
Levi
Dayton OH
Installed the collars today. Went from 28.5” to close to 30.75”. Very pleased with the turn out. As a novice to intermediate DIY hobbyist, I’d say this was closer to intermediate due to the spring compression. The spring compressors are only about $25 on Amazon so it’s definitely worth an attempt if your up for the challenge. Hope the pictures help you gauge wether or not you want to try it yourself. I’ll add that compressing the springs would be much easier with a hydraulic press. I had a second set of hands which also made it manageable. Hats off to SVC for making a quality product. It’s beefy, aesthetically pleasing and looks built to last. I highly recommend!
Cape Cruiser
Bret
Southern Delaware
retired mechanic
Guys, be careful with these $25 dollar spring compressors. As you see in the picture the bolt is bending. If that spring is removed from strut and it becomes uncaged the spring will get very angry! Stay safe and enjoy your trucks. Bret
Levcrowley
Levi
Dayton OH
Cape, is right. I winced with every turn on the first spring compression. I read lots of reviews and made sure the tool was rated for far higher resistance than I was putting in through although it bent nonetheless. Shop thoroughly on a spring compressor and wear a face shield!
rooster
BOS
STX FX4 SuperCrew
JaysOnTheEDGE
Jay
Unfortunately the better options for spring compressors are in the $800ish range ...
https://www.branick.com/product/7600-strut-spring-compressor/
https://www.otctools.com/products/strut-tamer-ii-extreme
For the backyard mechanic I think spring compression will always remain a thrill...
I try to have a 2nd vehicle when i do work that needs a spring compressor i take the assemblies up to my local tire kingdom or somewhere like that and the guys will usually do it for $40 cash real quick with the wall mounted unit they have.
Whiskeybilt
Jamison
Virgin islands
2019 ranger
chef
What's the advantage to a level like this, as opposed to the top spacers.
Stic-o
Lake View Terrace, CA
Since this never got answered, this will give you better travel then a top spacer. This also keeps your CV's at a better angle, and still gives you a good ride. This concept is very similar to a Bilstein, Eibach or Fox Cir Clip lift strut. Your just preloading the spring, which gains height. A true threaded coilover works the same too.
