Start-X Remote Start
dapakattack
Daniel
North Texas
2020 Ranger XLT 4x4
Added one a few months ago. The OBDII connector can be a pain to get out (YMMV). Just be aware that the range is limited to that of your key fob. If I am inside I'll use Ford Pass (if it is working) to remote start. If I am walking to my truck, I usually have my keys in my hand and will start it that way.
jdagg2003
Maize, KS
2019 Ranger XLT 2wd
Installed one in my father's fusion, works great. 10 minute job, just no room for your hands in so I busted up my knuckles pretty good, don't know if there is more room in the ranger.
Are you able to set the timer on how long it stays on? I just ordered one.
Truck is on its own timer with any of the remote starts. I believe you can change the duration in dash settings iirc
Jmarler
Jimmy
San Antonio
2021 ranger
Certified Hacker. Retired Veteran
How do I disconnect the cable they are talking about?
Jmarler
Jimmy
San Antonio
2021 ranger
Can some one me how you connected it? I have a 2021 ranger and I don't see a way to disconnect the obd2.
VegasRanger
VegasRanger
Las Vegas
2021 STX Crew Cab 4x4
Damper Salesman
Push down on the tab and pull back. The tab is at the top of that connector.
Jmarler
Jimmy
San Antonio
2021 ranger
I'll give it a try but it looks like one whole piece
Jmarler
Jimmy
San Antonio
2021 ranger
9i
What year is your ranger? I'm wondering if the 2021 is different. Because I have been trying it and I'm not finding any tab to pull.
Jmarler
Jimmy
San Antonio
2021 ranger
This how mine looks
VegasRanger
VegasRanger
Las Vegas
Damper Salesman
This how mine looks
Mine is a 2021. I have to double check but mine came out super easy, I’m pretty sure I pressed down on a tab on top.
Jmarler
Jimmy
San Antonio
2021 ranger
I'll give it another shot but I'm about to return it. Is the tab in front or behind?
IIRC there should be two bolts holding the plastic housing for the ODB port in. If you take those off the whole black piece will come out and it'll be easier to get to the ODB port once it's down.
Jmarler
Jimmy
San Antonio
2021 ranger
I got it off but tharness doesn't fit
Was yours the same size?
Jmarler
Jimmy
San Antonio
2021 ranger
Did your t harness look like this? It doesn't fit mine.
