SPD Performance Downpipe
Ranger2020zoomzoom
Patrick
Mesa
Ford Ranger
Na
No concern for me, there seems to be enough clearance, more than stock. But no heat shields like the stock had on it
Some guys have wrapped theirs, I didn't
Usually runs around 550-750 if I'm on it for the cat temps but cools down pretty quickly
On hot days I'll crack the hood after a good drive
Nice! Okay cool, I threw my first code after about 15 miles. P0420, I’ll have to do the defouler. Did you do a tune after you installed yours? Thanks for the info !
yamahaSHO
Greenwood, AR
www.jaztuning.com
You're fucking with me, right?
Did you really just respond to my comment....
With this?
I've been driving and modding factory turbocharged cars for over 20 years. An untuned for downpipe is, has been, and always will be a recipe for disaster.
Do with your truck as you wish. As I said in my first response to you, hopefully you can run it without a tune, or problems forever.
Of course throttle response is improved, you're moving more air, and boost is building faster. Problem is all that additional air from your increased airflow doesn't get any additional fuel to compensate. Without a doubt at a minimum your engine is seeing sporadic lean conditions, if it's not always running lean. I would be curious to see your dyno chart for the "power accross the range" comment though. But something tells me that if you're to cheap to tune for your downpipe you haven't dyno'd it.
Tuning is a bit better than the days of GD Subaru's (and any EJ Subaru at that). Although I do agree that you'd want to tune for a downpipe, it's not quite the same as it used to be in erratic boost control, boost creep, and potentially running lean. I haven't looked any of the Ranger maps, yet anyway, but I'd imagine the VE table has a bit more resolution and these days, ECU's are always in closed loop and can keep the the AFR pretty close to target, which is probably richer than I'd run on a tune, anyway.
Many of the newer cars I tune, for example (not the only example) a GT-R, you can add downpipes and intakes and the car is not going to destroy itself. It actually runs commanded AFR, however, in tuning, I can manipulate, boost, timing, VE & MAF, and commanded fuel to get good, safe power.
I know the Subaru game... Aside from owning one for awhile, I have been tuning them for a long time. They still blow up easily.
Again, I still recommend a proper, not OTS, tune.
Ranger2020zoomzoom
Patrick
Mesa
Ford Ranger
Na
Thank you so much for the response! Yeah it’s totally true about the OTS tune. Has me worried a bit not even gonna lie.
For sure. While ECUs and factory tuning have advanced I still wouldn't trust it
Personally, I don't trust many of the OTS tunes available. Even on a stock truck.
Mustang2Ranger
Garrett
Southern California
I ran it for a few thousand miles with no code and no defouler mod. SPD said on the website it would not throw a code. Then I had saved for the tune eventually, and Livernois adjusted for it
StezenW
Stephen
Atlanta
Grady
Christopher
Dallas
19 Ranger FX4, 17 Subaru BRZ Yellow, 11 Evora
Manager
Are you concerned at all about the heat that radiates off the new DP? I am worried about the coolant lines above the down pipe turbo area, also the transmission being cooked. Not sure if I like my down pipe. Does yours run super hot?
Header wrap, it works on down pipes also. That is what I did. Although performance wise you want as much heat to dissipate after the turbo as possible.
Mrmonk7663
Michael
Houston
2020 Ford Ranger
@Andy ice little write up. Thank you. I was able to get my DP off just now in about an hour using your post as a guide (already had exhaust off) The initial torque needed to break the nuts is high. I used the harbor freight LONG 15mm wrench and it had enough length to make it fairly simple. The inner nut I used the deep well with extension and then used a step stool so I could get both hands on it. Bottom one I used wrench from the bottom.
Travis9935
Travis
The Midwest
2021 Ranger
Turns out you do not need to be tuned for exhaust mods. Via Livernois. They said it's a Speed density motor.. No need
Superdannyboy
There are 2 things that are driving me crazy.
1) I can't seem to disconnect the factory downpipe from the flex pipe
2) I can't disconnect the lower O2 sensor plastic connection
  • Sad
808matt
Matt
Hawaii
2019 Ranger FX4 Sport Package, 2015 f450 Bucket Truck
1. the clamp or pulling them apart?
2. Not sure how to help you there. Mine came apart, it’s just a matter of finding that release button and leverage to pull apart
Superdannyboy
Pulling the pipes apart lol.
I took the nut off the clamp it's loose, but boy oh boy the pipes are hard to pull apart.
I can disconnect the electric connection once I pull the pipes apart.
