source for high beam light trigger
helios
james
'19 lariat 501, '21 Lariat 501 tremor
cdl
I am looking to add a pair of lights. I want them to come on with the high beams. where is a good point to get a high beam trigger?
Davejb
New Hampshire
2020 Ranger XL STX
Back in the day I used a relay running right off the high beam wire at the headlight, this puts the new light load on the relay and not the factory wiring. Unsure if this would upset the computer though in todays vehicles.
helios
james
cdl
perfect! thank you!
helios
james
cdl
again thank you! but i dont know if i did something wrong or my truck is different then the unit Stedi designed the harness for but it does not work. wonder if the wiring is different with the LED lights? on mine i get nothing to the y harness and a left turnsignal hyperflash
Might be different between us to the rest of the world. This has been an unfortunate truth. But hey, someone was willing to find out!!
helios
james
cdl
yes, but it is still a good product, I just need to figure out which wire is highbeam and re- wire
the Stedi plugs to make it work.
FYI, You need to be careful when adding lights that are on with the high beams. Many states have laws forbidding more than 4 forward facing lights on at the same time. Our low beams stay on with the high beams, so that is it. I know people are running them on road but they are Violating the law, and are liable for a fine. Extra lights are for off-road only. That's why fog/driving lights are wired to turn off with high beams. Technically Bambi mode is illegal under these laws. As I said, I know people are doing it, because it looks cool, and to have more vision. But, depending on how the LEO feels they could be ticketed and fined.
helios
james
cdl
thanks, I am aware of that but the lights I am adding are sae compliant for use on road. and since the low and highs share the same projector, I think there is a bit of grey area on that.
True, your Lariat may be an exception. One of our LEO members will need to weigh-in.
Mike Z
Long Beach, NY
2021 Ranger
Hey all, I just hooked up some lights using the Stedi piggyback harness to tap into a high beam trigger. The Stedi harness is wired to tap into pins 1 and 4 which must be the EU/AU spec. I used the wiring diagram linked below to identify that in the US we need to tap pins 1 and 3. I re spliced the stedi harness, and while I was at it I also tapped into pin 5 on the harness to get a parking light trigger. This way if I ever want to go back to stock I just remove this adapter and my stock wiring is pristine. Hope this helps
https://www.ranger5g.com/forum/threads/schematic-and-harness-for-headlights.8703/
