Bat-1
Oh, great the 10R80 trans now this for the extra 2200 they charge they need to include a gun for anybody that buys one equipped with both.
The first 6G with the 2.7 has already been delivered as per 6G forum.6g 2.7l I believe has not started production yet and I do know there is a solution in place implementation is still taking place however, can't say much more at the moment (insider trading type of thing)
Would like to some time with the miles on this system before I would buy. I hold on to my vehicles for a long time and high miles. My last f150 was 17 years old with 245k when I got the Ranger.Wow! The same panic, disbelief and "not me" saying on every forum I've looked at.
The 2.7 and 5.0 engines have been using this system since 2018. How many engines is that? How many failures have me heard about, directly attributed to the belt failing?
Fine if it is such a bad design, prove it. Let's see the data! What is the failure rate per 100K miles.
This is becoming a worse witch hunt than the 10R80 transmission.
Two entirely different use cases. The major issue with the Ecoblue application appears to be use of a wet belt for cam timing. And any belt wear particles/pieces getting into oil sump. This is a completely different use than driving an oil pump. Much higher loads and tensioning. Even dry timing belts have a shorter replacement recommendation than chains or gears. Usually in the 60K to 100K range. The oil pump belt is basically non tensioned will a much smaller relatively constant load. So, wear is minimal.Those who say they've never heard of any problems - look up "Ecoblue timing belt issues" They've used this design for quite some time in Europe for both timing and oil pump belt design in ecoboost engines. And it's not been exactly widely successful. The 2.0 bi turbo diesel available as the base engine over here features both and I wouldn't touch it except as a short term lease car. Dry belts, gears, or chains for me!
How much time do you need? It has been used since 2018 in both the 2.7 and the 5.0.Would like to some time with the miles on this system before I would buy. I hold on to my vehicles for a long time and high miles. My last f150 was 17 years old with 245k when I got the Ranger.
I want to see a longer track record.
Longer than 7 years. I've never had or even seen an oil pump fail on any Fords in my family or friends. These belts are going to wear out unlike shaft or gear driven. As far as chains they should last a lot longer than a belt I just don't know how far.How much time do you need? It has been used since 2018 in both the 2.7 and the 5.0.
