RCMUSTANG's Magnetic FX4
I'll have to look when I get a chance. Go through the easy change menu and see if any of that works. Or try reinstalling the 19101 again, download 19247 again and reinstall. It's possible the file wasn't complete or corrupted. If the higher one still doesn't have it you might just have to stick with 19101.
There was a couple options in the "easy" menu but no dice. At least I still have my heated seat icons in the home screen, though.
It isn't a huge deal since I almost never use the climate page on the sync screen - I just wish I could understand why I don't have it.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
I forgot to ask which version did you stop at?
I didn't go any farther than 19101 - I think that is the one that installs from that download - I didn't want to do the optional install - maybe I should?
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Try the last 19274. Which version did you choose for the second USB?
19101 - I can try and download 19274 and see what happens. I believe I should be able to install it over the top of what I have currently.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Yeah. I did that and everything went fine.
Trey1940
Trey
Martha's Vineyard, MA
2016 Fiesta ST, 2019 Ranger Lariat FX4 Sport
Loving all of the detail work you're putting into this truck! With Sync 3.4, is it just Google Maps or any navigation app working in the productivity screen? Just curious, I use Waze more often than Google Maps.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Thanks. Factory nav already does that but Google maps never did. I don't use any other apps so I can't verify.
Upgraded to 19274 but still no climate menu - played with a few settings again but no change. Reverted my APIM to original and still no change. This is what I have now for those two values:
I know the 3 in the last quartet of 7D0-01-01 is to display the heated seat controls in the home screen. I also tried a 2 in the second position of the second quartet in 7D-01-02 as I saw in some reports but that didn't change anything. The only change from my original settings is that 3 in the 7D-01-01.
A bit frustrated....
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Apparently there's a fix. https://www.saeb.net/viewtopic.php?f=66&t=3312&start=25
I got the file and am comparing the detlas to what I have. I will experiment tonight to see if it fixes it.
SUCCESS!! I'm not quite sure what the magic value(s) were (I was only trying to change exactly what I needed to) - I ended up changing 4 values to match the file that was attached here and after a couple attempts and power cycles, my climate menu returned.
These are the values I changed:
7D-01-01 AA2A 0403 03B7 - Note: I know the 3 in 03B7 turns on the heated seat icon on the home page
7D-01-02 022A 0204 8894
7D-02-01 5753 0106 C04B - the last quartet I had to do a couple of times - it kept changing to C04F after I wrote the data - it finally stuck after a couple attempts
7D-04-01 0000 3300 0D1C
Anthony
Anthony
Connecticut
COO
Woot! I know what I’m doing tomorrow! Glad you guys got 3.4 working!
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Mine worked the first shot. It seems there are a few that have an issue.
I've only found one quirk thus far - I seem to have been "converted" to a non US spec - Radio stations have two digits after the decimal and the speed limit signs display a circle with a red border (which is a European standard I think). Anyway, I recall hearing that if you enable navigation in motion it will display radio stations with 2 digits. I'm thinking this value might have done it:
I think the 5753 should be 5553 for US vehicles. I will try that change tonight to see what happens.
