Rain Sense Wipers
garo1943
Gary
2019 Ranger Lariat/2019 lincoln Navigator/2015 Volkswagen Bettle R/Line Convertible
Has anyone had there wipers come on randomly and wipe a few times and then turns off.
Dhass68
Dan
Kelowna B.C.
2020 Ranger XLT
Brake and Suspension mechanic
I hated the rain sensing wipers in my wife's '16 titanium Escape
Yes they did wipe once in awhile out of nowhere
Nick Barber
Nick
Richland, WA
2019 Lariat, FX4, White Platinum, Chrome, Tow
Program Manager
There is a courtesy wipe option you can enable/disable in the HUD, and if you leave your wiper selector in the column in the intermittent position they may sense a need to wipe occasionally.
ALranger
Eric
2019 Ranger XLT
MRI tech
I thought the courtesy wipe was an extra, delayed wipe after you run some washer fluid.
garo1943
Gary
My SA said he had never heard of this. REALLY I was on the interstate today was 94 degrees and clear and it wiped once
Hi Gary,
Clean the windshield around the front facing camera. Bug splats will also cause wiper activation. Camera can not tell a bug from a rail drop....
SymChris
Mississauga, ON, Canada
2019 Ranger Lariat FX4 / 2017 Escape SE FWD
I forgot to turn mine back on this spring/summer. It didn’t work the greatest this past winter so I turned it off. It was understandable because conditions were right at that point where it’s either too little or too much.
Going to turn it back on :)
Hi Gary,
Just an FYI, the front facing camera is at the top center of the windshield in front of the rear view mirror.
Clump
Charlie
Felton, DE
2022 Explorer ST former 2021 Ranger Lariat Tremor
Mine does a random wipe now and then also.
We've had some overnight storms lately where the windshield has a lot of water on it in the morning, but not actually raining and when I start the truck no wipe at all. Maybe I'm not giving it enough time before I intervene?
Hi Charlie,
Hmmmm....not sure but maybe speed sensitive wipers at zero speed do not wipe? Maybe not in drive? Just a guess....
Motorpsychology
Prescott, WI
Vagabond
I wonder if it could be that the sensor gets blocked by dead bugs or bird droppings? On my Escape, I've had a message come up with something about the camera for anti collision braking, etc is blocked and I need to clean the lens. It's behind the lower gravel shield, which collects a lot of bugs and road debris. the warning goes away by itself after about 15 minutes.
I have turned off all of the "driver annoyance" features that can be done without Forscan.
