PPE Install and removing heat shields
f1loco
Don
2018 JAG F-Type 400S - last of the British Fords
So, on my 2021, finally got around to installing the PPE pan, changing filter and oil. Any real down side to not reinstalling the flimsy metal shields? I read on other forums Ford only put them on b/c they were having to warranty too many of the plastic pans because of warping. Figure PPE is way better for cooling in any event.
f1loco
Don
I liked the naked look - not that I hang out under my truck that much. LOL Just having 2nd thoughts.
I think it’s more to divert heat from the CAT away from the transmission, not so much for pan protection. CAT heating the transmission fluid. It get pretty hot at that point / area. If you have done a fluid level check with the OE stick, you will note this - very quickly.
f1loco
Don
Yes, only takes a second. Got my MBS stick on order. :D Wonder if you can wrap that part of the cat/exhaust with some good header tape and accomplish the same thing?
RangerBill
I wouldn't insulate the CAT. The higher temps inside it may destroy it.
Reactions: TJC
f1loco
Don
Count on 3-4 hours. Draining and cleaning probably the longest part of the process, along with the fill. MBS will greatly shorten the later.
theprinceofsnj
Richard
Clayton NJ
2019 Ford RangerXL 1959 Edsel Villager 9 passenger
That reminds me of what happened with 1958 Edsel's equipped with Teletouch. (push button automatic) Mechanics would toss the heat shield.
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
I wondered the same, but put them back.
This.
'It looks better' is not a valid reason to shed more heat into the fluid. Might be miniscule, but still.
Reactions: TJC
2021Ranger
Barry
NJ
2021 Ranger
next time it will a lot shorter and I tested the new funnel Mike had made and it works great..
f1loco
Don
Just measure what came out as a base and go slow on adding after that, but watch the back of the hand and that dang CAT. Once the new dipstick is here and installed, will be so much easier next time and easy pump out of go too fast on the fluid.
The Last Ranger
Mass.
2021 Lariat
I just checked my PPE trans pan that the dealer installed and yes they installed the shield on the passenger side near the cat.
f1loco
Don
Yup, got mine fitted on as well, but do watch he sharp edges when doing so.
