Post your off-road pics.
Brett Fields
Brett
Brooklyn
Paramedic
Mighty Little Blue
Printer/Retired
Sorry I did not take a photo but, 4 wheeled for the first time two weeks ago when I put my mine up on ramps to put my Fitz stick in quite exhilarating. I have had it two years.
Even if you do not offroad you should drive some in 4 wheel drive. Not good on the system to go unused. Just make sure you drive in a straight line and do not make any sharp turns unless you are on a dirt road were you can have wheel spin. I would think there is some info about this in the manual, I do not have mine available to check.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
This isn't actually true in *most* modern trucks anymore.
The reason that was a suggestion in the older days is due to the fact that front hubs were disengaged when not in 4wd, but most newer vehicles don't disengage at the hubs anymore, the front driveline is constantly spinning even if it's not powered. The 5g+ Rangers are included in that population.
Mighty Little Blue
Printer/Retired
Did not know that thanks for the update. So the transfer case and front differential gears are always turning?
Little family vacation at the beach this summer and spotted this guy.. ?
That’s pretty cool. I’d drive it.
You didn’t see this guy getting out of it, did you?
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Yes, in every typical 4x4 the transfer case is always turning as it's connected right to your transmission, regardless of the gear selection the fluid is flowing. And in most vehicles these days the front diff is always turning as well, it definitely does in the Ranger.
Mighty Little Blue
Printer/Retired
  1. Yes, in every typical 4x4 the transfer case is always turning as it's connected right to your transmission, regardless of the gear selection the fluid is flowing. And in most vehicles these days the front diff is always turning as well, it definitely does in the Ranger.
    Thanks, learned something new today. This forum is a great place.
a6m5
'22 Ranger XL
My '22 Ranger has had quite a year in 2024. All in Oregon & these were my personal favorites:
March - We went target shooting, but it turned into a series of recovery missions rescuing each other stuck or in the ditch instead. lol
I always have a shovel, traction boards, air compressor, recovery gear on board, so it was great training pulling vehicles out. lol
April - Hole in the Ground(volcanic crater in Central Oregon)
June - Off-road trail near Mt. Hood
Couple weeks ago - Southeast Oregon
My friend's Ranger on the left. This last trip was very challenging to me because of distance(around 1,000 miles of hwy + off-road driving) & one trail which felt like 100 miles long & made up of big sharp rocks. Rangers are awesome trucks though. I just hope the 10 speed tranny holds up!
Dmitri
Dmitri
Los Angeles
2023 XLT FX4
Yup, pretty much. I extended the line way up to the top of the hood basically and put a filter on it.
Can you do some pics with front breathers location? I found only one near the oil filter. As I understand Ranger has 3 breathers, rear diff, front diff and transf. case.?
Thanks.
tygr2007
Tyler
Naples, FL
www.tradewindnaples.com
Designer @ Tradewind Designs
Thanks.
I’ll @ you later today and make a post about that.
