Pics of Tremor with 1" wheel spacers? Wheel rub?
McDeuce
2021 Ranger Lariat Tremor
Robby just shipped my 1" coil over spacers today (BTW he is awesome to deal with). The plan is to install the spacers and check clearance. Then either install 1" or 1 .5" wheel spacers. . . . Best bet is hang a plumb Bob from the center of wheel well and measure out from tire. This should give you an idea of how far your tire will be pushed out
Good Morning, Did you work out what wheel spacers will fit? I wondered if you did it yet. Thanks
awd.nv
awd.nv
Anthony
Las Vegas, NV
'21 Ranger XLT Tremor
Computers
Well, 1" wheel spacers fit without a lift, MAYBE 1.5" with 1" life. I just had to push out my crash bars in the front. I get a tiny bit of wheel rub in reverse only in one direction so I might double check that side to see if the crash bar can move up some more. With the 1" lift, it would just gain in clearance.
So if you want to play it safe, get the 1" wheel spacers. 1.5" will likely be no issue with the 1" lift if you want the wheels to stick out a little more.
1" is subtle in pictures but here they are installed on stock Tremor height.
McDeuce
Thank you Anthony !
