WindRock off road park killed my Ford Ranger...
TheDo114
Canada
2021 Ranger Tremor XLT
So wait, how is the Bronco sold as having 33" of water fording ability if it has the same stupid alternator placement?
Ford states in the Bronco owner's manual that with the sasquatch package (lift and 35 inch tires) you can go up to 33.5 inches of water fording capability and that anything else is 31.5 inches.
It's really weird to me that we get very different rating for the same engine and tire height. There has to be something else going on here.
Glocker
Boca Raton
Having checked out both a Sasquatch and non-Sasquatch, the tires on the Sasquatch Broncos are huge compared to the lesser Broncos. I can see it creating the difference in the fording abilities.
TheDo114
Canada
What
Absolutely! 35 vs 31 is massive and justify the upgrades. What I don't get, is the rating for the bronco's that come with 31, 32 or 33 inch tires compare to our ranger's that come with the same size tire. The alternator placement is the same, roughly equal to the top of the tire on both machine but the bronco get's 31 inches and we get bottom of the hub.
Glocker
Boca Raton
What
Ahhhh. I gotcha!
I was really hoping the Bronco 2.3 came with a better alternator than ours. I don't know squat about sealed units and plumbing them for cooling so I'm doubtful I will be messing with that. Ughhhh. Damn you Ford!
Kataphrakt
Tim
Grand Rapids Michigan
Ranger XLT FX4 Offroad
Mechanical Engineer - Mirrors
I suspect the difference may be due to the front transmission vent hose placement or the transfer case vent hose placement. I've tried to find the transfer case one multiple times (supposed to be visible in the engine bay) but couldnt track it down.
Otherwise, it's probably an oversight. Ford manuals generally state no water fording above the hub cap on trucks, and only up to the hub cap on cars. (Ranger manual states the latter IIRC, which is lower than an FX4's ground clearance)
EDIT: My benchmark source doesnt have the new bronco teardown yet. If it pops up i'll see what's different.
THLONE
Thom
Tucson,AZ
internet wise guy
In AZ we are the capital of people driving into wash full of water and drownings their vehicles and themselves. We have a stupid motorist law to fine them. But, they still persist.
"Turn around dont drown."
Jms81661
Las Vegas, NV
2020 XLT Ranger Sport
Truck Driver
Same here in Vegas. I'm bewildered at these people. The water is up to the door handle and they wonder why they couldn't make it,let alone their car/truck is now floating down the wash.?
Brett Fields
Brett
Brooklyn
Paramedic
I had actually seen Ethan's video a while ago. (Before finding this thread) I've been thinking about buying an alternator for my FX4 so I'd have it if ever I should need. The parts guy I was talking to said there were two. Mine, for around $300ish, and the Tremor for around $500ish. I'm guessing that the tremor part puts out more amperage? I would consider it if I knew it would retrofit in to my FX4. Can anyone shed light on this?
HarryManback
New England
2021 Ranger XLT Tremor
Electrical Engineer
This is the first I've heard of the Tremor having a higher output, but it makes sense given the upfitter switches. That's a potential for 65A additional load, it makes sense that they would have a bigger alternator.
ok im new and this is the first time i have learned of the easy to dunk alternator. i am so disappointed! one of my favorite things to do off road is splash in water and have the spray blind out the windshield for a few seconds. No, i am not the type to drive into flood water that is stupid high etc.
even my older ranger has the alternator up higher. what was ford thinking. ? any one tried slathering up the connections with a thick gooey grease and then going for a swim?
Some dielectric grease couldn't hurt.
But the biggest issue is really more mud and debris packing in from what I understand.
wonder if one could rig sort of shroud / shield out of the older style metal window screens. That might prevent globs of mud from getting mashed in the alternator guts. Smaller hole means less mud passes the screen compacting and cooking the alternator. the window screen would still breathe and be a little easier to check and clean after splash. folks would have to be sure to use the metal screen, most of the current screens are a plastic and would melt. ?
That doesn't sound unreasonable.
But it's highly dependant on airflow though. Are there enough gains to put in the work to screen it without effecting the cooling?
The sealed units used in Australia are really nice, just pricey. It's just that nobody has a US Ranger specific or proven arrangement yet.
Advanced Auto Parts has a Hitachi, I don't know if it could be made to work for us though.
https://shop.advanceautoparts.com/p...bu8n1GWa-TGlWWFcqxMaAiTrEALw_wcB&gclsrc=aw.ds
Motorpsychology
Prescott, WI
Vagabond
Where do they put the alternator on the 2.3L Broncos? Is it able to be mounted differently because of the wider track? (65" vs 61.4")
