Oil fill funnel
I use a 10" wide mouth...that 5 quart can really flow...
Reminds me of these…
Push the oil can - yes, can - with your palm, onto the piercer to open it, pull it back, rotate the can about 10°, pierce it again, and let it flow.
Aviation oil is still in cans, so I still have a can opener in my toolbox.
Friday yet?
‘23 Lariat Tremor, Focus ST
Flashbacks!
Completely forgot about those.
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
I won't argue on how nice those can be, but I feel this isn't needed on the Ranger
Really, I don't know about the Ecoboost, but the 3.2 diesel has a pissy little threaded hole through which you have to pour 9.7 litres of oil - yes the diesel holds almost 10 litres. Trying to balance a 10 litre container above that hole which is also a fair way back and I have a front bar as well, and not make a mess is almost impossible without a funnel, and one that stay's put would be even better. I keep meaning to 3-D print a threaded one, I currently have a floppy one (funnel) which is annoying when you're trying to keep it as full as possible so you can hold that 10 kilo weight at arms length for the minimum amount of time.
Was referring to the 2.3 since that is the only one I'm familiar with. As for the 3.2 I think I only delt with one from a transit and it was something else to say the least.
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
Thanks for the info, that's useful to know if I do decide to make one.
brroberts
Randy
Overbrook, KS
audio / semi retired
Bought the Motivx mentioned on the forum a couple of years ago and did the sand/grind down mod so it fits perfectly. It’s just nice not to have to hold the funnel while pouring. Like a damper, not essential, but nice. The damper simply made me too weak to hold the funnel anymore.
DonS
Don
Pa.
2020 Ranger xt SXT
You dont have to do any sanding or grinding this one, fits perfectly as is.
Desert Sage
Lowell
Arizona
2020 Ford Ranger Lariat FX4 Supercrew
Educator
Thank you- I never knew about a Assenmacher funnel that would work with my Ranger. I bought an Assenmacher funnel (yellow #1042) for my WRX, and it really sped up the time it took for oil changes.
I now use my old yellow funnel for my Ranger- but underneath the car- I hold it tightly with one hand as I pull out the drain plug, and the fast exiting old oil hits the top of the funnel (and not my front suspension) and it directs the old oil down to the waiting drain pan. A glove might be needed to insulate your hand while holding the funnel if draining hot oil, but realize the funnel only has to be held for the initial gush of used oil.
Now if I can only better orchestrate those dang plastic splash guard rivets (#@%&*@!!).
DonS
Don
Pa.
2020 Ranger xt SXT
I also had the Assenmacher funnel (yellow #1042) for my Forester, i was great as
well
Grandaccess
Robert
Binghamton, N.Y
2021 Ford Ranger XLT FX4
Computer Consultant
What happened to the little white one that comes with the truck in the Emergency pack under the back seat?
