Oil Drain Plug Part#
Husky44
Domenic
NorCal & Idaho
2021 Ford Ranger 2014 F150 Raptor
Anyone know the Ford part number? Thanks
CO2Ranger
If you're going to spend the money anyway and change your own oil, at least look at the ValvoMax setup. I got one for mine. Was tired of splashing oil all over the garage floor.
Husky44
Husky44
Domenic
NorCal & Idaho
9L8Z6730A
Thank you
Thank you for the suggestion, appreciate it.
I only put 5k miles a year on the trucks (now 2-3k on the Raptor and Ranger), ride a MC most of the year. I'll give some thought to installing this system. I'm retired and have nothing but time and just changed the oil at 1K, other than removing the skid plate wasn't that bad.
RAYJAY
UNION DALE PA
also once installed you do not have to drop the skid plate.....
How does that work? Do you have to hold that lever up the entire time you are draining the oil?
First off you don't have to remove skid plate for a change. (You do 1 time to install it) Attach the hose fitting. Then pull a plastic lock clip, and open the valve. It stays open. Takes a few minutes longer but not bad. When done, flip the lever closed and remove the hose and put the safety clip back on. It's that easy and no mess. I can drop my filter and run the hose simultaneously in the same pan.
Matsterious
Matt
Houston, TX
2022 Ford Bronco Big Bend 2.7L Mid Package 4.27
Whelp... I know have another item on my list to purchase. Thanks for the info!
CO2Ranger
RAYJAY
UNION DALE PA
I looked at these. Short term fine. Long term with road grit and other gunk buildup I thought twice about it.
Maybe throw some anti-seize on the threads and it should be fine.
RAYJAY
UNION DALE PA
no dirt can get into the valve the cap takes care of it
