Oil Catch Can. Yes or No?
Do you have a catch can?
  • Total voters
    44
seanellaz
Sean
Tucson, AZ
Healthcare
Oil Separator, Part #: 6A785. On the side of the motor, between block and Turbo
BTW, the purple colored hose, part # 6A664, is a bendable corrugated hose. It is where aftermarket Catch Cans tap into the PCV system. Rather than pay CRAZY $200 for a kit containing $15 of hose and a $25 catch can with a bronze filter. I am thinking of just cutting this hose, adding some fuel grade hose, and inserting a catch can in the loop. The custom fit "Kits" are SUPER HIGH Profit margin quasi ripoffs.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
I've seen other owners of vehicles basically build their own using the factory connections. I don't see that buying a well-engineered kit as a 'rip-off' because you are paying others for their time and research.
I don't even fault those who dismiss the 'need' for a catch can either - it comes down to the perceived value and goals of the owner. I've seen some things done to cars that just screw up the vehicle from my perspective but I'm still enough of a Libertarian to say to myself that as long as it 'neither picks my pocket, nor breaks my leg' I don't care.
Justlooking
Scott
GMC 1500 AT4 6.2L
Know nothing about this.
Can someone explain?
I realize I’m replying to an old post but I didn’t know what a catch can was for either and I really didn’t understand the answer given above. This video gives a great explanation. I guess I need a picture to understand things!
Justlooking
Scott
GMC 1500 AT4 6.2L
^^^This ^^^
Please...no disrespect intended but Im not sure why owners think its a good idea to redesign vehicles and other recomendations engineers make. There are years of design and testing that goes into these things.
Catch can: if it needed it, Ford would have designed it in. I would venture to guess that a very large number of Ecoboost engines run fine and for a long time without it. There are a tiny few (%) that feel it needs it.
Oil: Ford knows what kind of oil it's engines need. Not sure why some owners feel they know more then the folks that engineered it.
I’m not sure how one can conclude that engineers at Ford didn’t think it was needed. As someone who spent his career in engineering and product development I would say the odds are very high that it was the accountants who didn’t think it was needed. You would probably be surprised at the number of suboptimal compromises engineers are forced to make in order to hit cost targets.
Doc
Doc
Live oak fla
Racket
Here and There
Transient
Thus far catchcans have been touting the extraction of vented oil and preventing it from reaching the intake.
You seem to now claim that a catchcan actually improves crankcase ventilation?
If anything, a catchcan would restrict ventilation, certainly not enhance it.
Not when there is a vacuum pulling it. And in my case I have a second source. When you have vacuum in excess of pressure behind the separator there is no significant restrictions. That's simple reasoning - this is a draw-through filter, not inflating a balloon.
Floyd
illinois
Not when there is a vacuum pulling it. And in my case I have a second source. When you have vacuum in excess of pressure behind the separator there is no significant restrictions. That's simple reasoning.
:idea:Right... simple reasoning... got it! :wink::giggle:
Racket
Here and There
Transient
Racket
Here and There
Transient
You're right, not 'needed' is key. The bean counters were the driving factor here.
The truck will of course not fail as delivered, but I'm pretty sure the technical consensus is that the pollution control system re-introduces crud from the engine back into it (as PCV systems have done since inception) and rather than defeat them as enthusiasts did in the past the catch keeps more of it out.
seanellaz
Sean
Tucson, AZ
Healthcare
Point well taken Racket. I put on the Cat Back Exhaust, wrapped it in fiberglass myself, installed the injen intake kit myself, installed the BDS intrusion beams myself. I am happy to pay a shop to install the 3.5" BDS Lift kit w/ UCA's, 1" shackle lift - paying them for their time and mechanical knowledge. Sorry if I seemed to diss those who buy off the shelf Catch can kits. I am still figuring on a design for my truck (2-3 hrs so far), then installation (another 1-2 hrs) . Perhaps in the end it would be more efficient to just buy one off the shelf. If the system I put in does not blow up I will share it on this forum. I am uber libertarian myself.
TORQUERULES
US
Ranger
This is as on point as anything said in this thread so far.
txquailguy
Biologist
I'm seeing some things that really interest me about this catch can debate. Octane of fuel used, outside air temp, and how heavy your foot is seem to be directly correlated to what you will catch in that can. It has definitely been changing with each dump. When/if I get some kind of handle on this I'll post some results/findings.
Justlooking
Scott
GMC 1500 AT4 6.2L
As I’ve thoght about how a catch can integrates in with the system I can see where there could be issues with a can increasing back pressure if not designed exactly correct for a given engine. Not sure what all of the consequences might be? If the crank case is not properly vented oil could leak from everywhere? (I had that happen once with a faulty PCV valve). I suppose it could also create more blow by and force fuel into the oil? At any rate it seems the can would need to ensure no change in system pressure?
richmondjd11
2020 Ford Ranger XLT
Military
This was the amount of oil pulled out after the first 1000 miles after installing a oil catch can. Standard size solo cup for reference. Catch can was roughly half full.
