- First Name
- Steve
- Joined
- Jul 1, 2021
- Threads
- 84
- Messages
- 5,861
- Reaction score
- 29,203
- Location
- Fishersville, Va.
- Vehicle(s)
- Previous 2021 Ranger, Now 2019 Ford Expedition
- Occupation
- Navy Vet., Retired Police Sgt., Grumpy Old Senior Citizen
- Thread starter
- #1
Returned just this afternoon from a trip towing our travel trailer. Total towing was 1851 miles, and that was towing the trailer the entire time....no solo.
Met friends and were using their Toyo Crew Cab Tacoma as my Ranger is a Scab.
Overall, mileage was 9.8 mpg via the Rangers info and 9.7 via my installed Scan Gauge 3. This was using 91 and 93 octane, and running 60-65 mph on interstates and 50-55 on US highways.
Ran into lots of wind, rain, long grades, ect, and Truck never missed a beat.
Important info....ran mostly in 7th gear, keeping rpm's up around 2600-2700 at speed. Found this eliminated lugging and gave faster acceleration when needed, and mileage did not seem to be worse.
I found that via the Scan Gauge the coolant and tranny fluid temps were usually very close to each other, usually between 195 to 205 degrees. The temps were actually a bit cooler in 7th gear rather in the 10 th overdrive gears. I guess the low rpm's when towing a heavy trailer tend to heat the fluids more due to lugging.
Coolant temps never got above 205, but tranny temp did get up to 211 while running into a strong head wind going up a long grade.....but it comes down and cools to 200-205 quickly.
My trailer is right at 7000 lbs, and Truck did an admirable job towing , not one problem.
Just posting for those of you who tow a heavy trailer...once you set it up right the Ranger is a capable tow vehicle with no problems as far as overheating or trans fluid problems.
