New TSB - Harsh Shifts - Covering (After 8-16-22) 22-23 Rangers Only
Note: This only is for the 2022 and 2023 Ranger - with a build date - On or After August 16, 2022
For those that have Build Dates - After August 16, 2022 and have the new design CDF Drum, this TSB was posted today.
This shows even though the new drum is installed that there is enough issues system wide to generate this TSB
Summary - This TSB covers the other side of August 16 2022, where the previous TSB's stopped the procedure steps of the TSB
Though I would share my finding - luckily, I have no issues
Sad, they didn't get it right after the changes.
There's no money for them in getting it right.
Just like there's no money for the pharmaceutical companies to cure you. A patient (customer) cured is a customer lost. :mad:
TxOTRRanger
Clay
Elwood, Texas
factory worker Tyson Foods
Sad part is, is that is Completely True.
There’s a fix for the fix? Oh man, that’s nuts. At times, it seems like everything is broken. 😞
Yeah the mid '22's were supposed to be updated and fixed but I guess nothing is ever truly fixed right. So far mine's running good and I'm not going to do the TSB and I'll drive it 'till the wheels fall off!
Stevedbvik1
2022 Ranger Tremor XLT
According to this latest TSB it looks like the updated outer shell or trash can began being installed in transmissions around September of 2024. So no production 5g’s have the updated shell. But any replacement transmissions built after 09/24 would have it. So my replacement transmission that was installed under warranty in 06/24 wouldn’t have the updated shell. Great 🤦‍♂️
Interesting. I have a 21 with a new trans under warranty in may 23. I have all the symptoms listed in the tsb, I wonder if they'd honor the work.
Tbh, the trans is so much better behaved than the original that I've just been dealing with it, but it's not *right*
HMM - That is VALID question to ask per the (Print Verbiage - NO) but the (WHAT IF) you have a transmission that was installed with that updated drum but not in the specified coverage years
Hocakes
FL
'22 Ranger Tremor
Mine was built May 2022 so I only have to do regular level worrying or what?
Stevedbvik1
Your worry factor is still at its original level. You still get to worry about the CDF drum and the trash can.
