New 2020 Ranger issues
daczone
2020 Ranger
Bought a 2020 Ranger Extracab (Lariat) yesterday, Love the truck, but when I got it home I had the dreaded door ajar (and the cargo light and puddle lights) would not go off. I disconnected the battery, and then used a screw driver to trigger the rear door latch and finally got it to go off, but in reading posts this is a known problem. Will Ford fix it?
Also the Ranger Bounce, I read reviews and on my test drive decided it wasn't too bad. But after a drive down a rough road I could clearly feel the bucking of the suspension. Is there a fix for that as well? (I do not have the FX2 package). I am not interested in replacing suspension parts that will raise the suspension as my dog needs to be able to jump into the bed. But would like to make the ride better.
I also ordered the hopkins tailgate assist (EASY LIFT) , anyone done that?
Much thanks in advance
codestp202
USA
Ranger
I'd start with rear shocks. I'm not happy with the side to side jarring of the suspension. I ordered some Bilstein rear shocks. It sounds like the Eibach, Bilstein, or Fox are the most popular and it sould help substantially. There are also more expensive options. Check out Stage 3 motorsports to see what's available. However, I would say stay away from Rough Country.
Most people are using the tailgate damper- sounds like a better use then the tailgate assist.
wanted33
Down south in Dixie
Mustang GT, Jeep Wrangler
Old used up LEO
Check your tire pressure. Dealers are notorious for not lowering it from the levels they're shipped at which usually around 45 PSI which is way too high.
That's was going to be my suggestion also Jason. My tires were all over 45 psi.
Dave, John also has a good suggestion. My Super Cab is the same. I just give the back doors a solid push to make sure they are closed. I don't slam them, I just keep my hand on the door and push until it's closed. Works for me.
Radioman
Kent
Roseville, CA
Ditto on the tire pressure, mine were at 45 lbs also. Lowering the pressure will greatly improve the ride. You might also check the level of the windshield washer fluid, mine was very low from the factory.
Markubis
Nashua, NH
Mechanical Engineer
I picked mine up and they had 40 PSI. Door sticker called for 30 PSI
Stevo56
Duluth, MN
2020 Ford Ranger XLT, 2023 Ford Edge SEL AWD, 2012 Ford Mustang
When I got mine, tire pressure was 41 psi. I noticed the rough ride coming home from the dealer. I'm running at 31 psi now and it seems fine.
NickTheEnforcer
Anthony
Northern Illinois
my truck as delivered with 54psi in ALL...
I'm running 30-32 and all is good.
Langwilliams
Langley
Lorain, Ohio
My tires were overinflated too off the lot. I run 32-34 psi. I replaced the rear shocks an IMO it was the best mod I've done as far as living with the ranger as my Daily Driver.
Tracy Bowman
Tracy
my tires were inflated properly.
suck on that beotches. and Happy Holidays to all ???
and you probably fixed the door latch yourself.
if it keeps doing it, then Ford will have no problem replacing it under warranty.
Merry Christmas RP! ?
Devil6
Germany
Mustang
On these very forum pages others have found that if you adjust your tire pressures you can lessen the bounce. With some experimentation you can find what works for you: rear 34-40 psi and front 32 to 38 psi.
The front is usually softer than the rear.
I also will lean slightly forward with my chest if the truck starts to bounce or buck. This gets my back off of the chair so my upper body is not being impacted. It isn’t optimal but prevents you from getting car sick.
Ontario Canada
2020 Ranger XLT
Picked my my Ranger on Wednesday. Haven't driven it much yet but noticed this.
