message when starting truck
I have an XL, so I don't have a screen like that. BUT ... I do get FordApp notices saying it's going into deep sleep and disabling remote start and other features.
I've had these messages since I first got my truck just over a year ago but the battery has not died yet.
If you can, I really like using a battery tender on mine and I plug it in a few times a month.
https://www.amazon.com/gp/product/B00CD44RQO
My "install": https://www.ranger5g.com/forum/thre...o-your-ranger-today.3511/page-996#post-464715
If you were to check battery voltage before starting the truck after it sits overnight, you will most likely see the battery voltage near or below 11.5 volts.
I did an extensive research thread on the charging system.
Other signs that the battery is failing are:
ASS stops working.
Passive Entry stops working - at the Drivers / Passenger Doors
Remote Start - stops working
Deep Sleep - messages from Ford Pass
Here:
Charging Sys-Full Description-Trigger Voltages-Test Results | 2019+ Ford Ranger and Raptor Forum (5th Generation) - Ranger5G.com
If you are in the excessive heat wave, note AGM Batteries do not perform well with constant high heat.
Try giving the battery a good charge (external charger) or replace the battery,
Some have disabled the BMS, and it appears to help keep the battery charged better.
Wytchdctr
Doug P.
Westside Htown, Texas
2021 XLT
Retired Military/HR Manager
Mine did that a lot more when new. It has been a while since I've seen that screen. Mine sort of did the opposite of what it should do; unless it took a really long time to get the battery up to a normal charge after it got off the delivery truck.
Please, someone your truck has shown you this message when turning on and what it means.
thank you
Says that when I don't start truck for couple days straight...nothing to worry about...
21Blackout
Brian
Ny
21 Ranger
Warranty Administrator for FMC
Most likely battery is getting weak however if you are using connected data send me your milage and vin and I can try to look into this for you some.
gtyates
Greg
Ranger, Explorer, Sport Trac
Manager
It means you are seeing the effects of a battery and charging system that is set to too low of a charging state by the factory. I used Forscan to reset mine to 90% of potential charge and I have never seen that message again... Factory setting is 75%, way too low.
doorbob
Nazareth, Pa
2022 Ranger XL
Garage door tech
Had the same thing but the battery was fine. Got a software update from Ford while doing service and the message never came back.
SigOris
Greenwood Maine
Retired DoD EE
Use the same product on our ranger and bs-ob, one for each and hard wired to battery with external connections. on managements bs I have to loop the wire through the door handle so it’s disconnected before backing out of the garage. Guess we’re getting trained for if we ever go ev ?
