- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,586
- Reaction score
- 8,757
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
Yes - as far as the table,
Since I actually saw 99% SOC and the Voltage Inferred was reading 12.71, note at this point the system was using the battery only and its voltage was reading 12.6 volts.
So even @ 90% SOC (Set) the system was able to see the battery being fully charged and it cut off the charging voltage completely and it set a new (Desired Gen Voltage Setpoint of 12.6)
it used battery voltage only (support) then when the (Current-Out) of the battery was great enough (dropped to 99%) it then triggered a new (Desired Gen Voltage of 13.4)
So then in turn a charging voltage was applied above 12.6 and the battery saw the input current.
Since there was a charge (current) being applied the BMS (Inferred Bat Voltage) increased to 13.5
This is what caused the SOC Reading to increase back up to 100%
Note: 100% on this reading was actually 12.71 Volts (Inferred Voltage)
So, the SOC (percent) we are seeing is derived from what the (Inferred Reading is) and I just find it coincidental that my SOC is set to 90% which would equal to about 12.75 as this chart is (NOT EXACT) is an approximate voltage.
So, 12.71 volts was held for a while - during battery only support and the (output) draw is what triggered the SOC to drop from 100% to 99%
I just happened to catch it as I was operating in a charge mode (Desired Set Point) when I switched off the Headlights - it removed the need for the generator to be (REQUIRED) and it lowered the Gen Setpoint Voltage to 12.6 Volts, so the battery had a higher voltage than the (Set Point) voltage.
It used the battery voltage (only) for a short period and when the (Inferred Voltage) sensed it dropped (I never saw anything) below 12.71, so I assume it's looking at 12.71 as its lower end of 100% of the 90% (Set).
The point of my rambling is that (Maybe) 100% SOC we are seeing is not actually 100% Voltage or 12.85 Volts.
But actually the 100% represents - 100% of the (90%) Set SOC
This is only for the (Inferred Voltage Reading)
as this would explain why @ 12.71 Volts, I saw a drop from 100% to 99% SOC, so it's possible that the chart holds true and 12.75 Volts is the high end of 90% and 12.71 is the low end of 90% (SET) which is why when it dropped (Reading) from 100% down to 99% and desired setpoint (increase) was enabled by the PCM to get the SOC (Reading) back to 100% which when all is said and done the true SOC is 90% (SET)
It all ties into the (Inferred Voltage), so if the (Inferred Voltage) is constantly above 12.71 Volts (which when the generator is charging) will always be above that voltage is how it reads the SOC.
I need to do a drive test - to see what it will do over a longer period than just garage testing for a better handle on what it's doing.
as if there is a constant charge on the battery, it will never see the SOC Lower, and I want to know by drive tests what the SOC behavior will be now (after my charge & repair cycles)
I believe it's the battery sulfation I appeared to have that was causing it to slowly increase, but for now it's just a theory - until I make a few drive tests.
Another (POSSIBLE) is that the (Inferred Voltage) is via the PCM and the Battery Estimated SOC is from the BCM
So, we can possibly assume that 90% SOC (BCM) is the same reading as the (PCM) Inferred Voltage expressed as a voltage vs (percent) - the PCM is inferring the percentage as a voltage.
Either way - both readings are coming from the BMS Sensor.
