- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,459
- Reaction score
- 8,523
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
I cannot find the article on it now from my research, I was thinking the same thing that the PCM was increasing the voltage, but the article stated that it used the coasting speed to generate the charging voltage and it is tied into the clutch pulley on the alternator.OK, now you have me totally confused! How does decoupling the alternator from the engine still drive it from the axles? Once you decouple the alternator there is nothing driving it but its own inertia.
As far as I understand the only way to increase the voltage output of the alternator is for the regulator curcuit to increase the voltage to the field coils in the alternators rotor. Which will increase the load the alternator puts on its drive. So spiking the voltage in an off throttle condition (coasting) would help with engine breaking.
I'm very interested in what exactly this alternator clutch does and how it fits into this whole charging system.
Either way it works by coasting/deceleration and the length of time (regenerative charge) is applied relates to coasting speed. Short Burst-on a straight road, and long continuing charge coasting down a hill.
So even with the PCM increasing the voltage and increasing friction on the pulley it still relies on the rotational speed of the drive axles.
I have never worked with the smart charge system and finding correct info on how the system operates is difficult, and there is tons of (I think's) on the internet for this system. Ford's manuals are very vague and has some inaccurate information as well. So that just compounds the hassle in obtaining correct and accurate information.
So, I did the best I could with the information I found in breaking down the system and how it operates. I can be wrong on some things and value any input to correct my mistakes in getting a complete accurate system operation, for all on here to benefit.
