Max lift on stock tremor setup?
Bludrok
Acampo, California
www.ranger5g.com
Hello,
I am interested in lifting my Tremor (once I get it lol), and was wondering what options I have without replacing the Fox 2.0.
I'm looking for front and rear, with maybe a slight level, so slightly more lift up front.
What kit(s) would I need, and who are the recommended manufacturers?
Thanks!
Steve23
Stephen
Maryland
2020 Ford Ranger Lariat
Software Engineer
If a level is all you want to get to then you need to lift the front ~ 3" for it to be dead level (For a non-tremor, I don't think the rake is as intense on a tremor). I went with Fox's adjustable coilovers (preloaded to 2.5" I adjusted to 3") and an Eibach block (will replace with some leafs later) in the rear so if I tow I'm not too nose up.
For 3" you have a lot of options and it depends on what you want to do. If its just for looks, then you can get a spacer kit (usually a few hundred bucks). If you're looking to actually use to the lift offroad then you want to go with some leveled struts or coilovers etc. Most common around here are:
- Fox
- Icon
- Blisten
- King
- Eibach
Or more extensive kits like Old Man Emu (talk to @Frenchy about that, I'm pretty sure he gets commission ;])
Theres a thread on here where people rate the stiffness/softness of the available kits. Probably in the suspension section.
So I guess also, why replace the Fox kit on there?
- Fox
- Icon
- Blisten
- King
- Eibach
One would think I do but i do not lol!!
Also the Tremor package comes from the Factory with the Fox 2.0 kit so therefore it already has a leveling kit on it.
Steve23
Stephen
Maryland
Software Engineer
Alright yeah so I'm not sure why the OP wants to swap it
Bludrok
Bludrok
Acampo, California
www.ranger5g.com
I do not want to swap it. I want to lift the truck a bit more than it is, without swapping the fox 2.0, so I am trying to figure out what my options are.
All you have to do is adjust the front up a little bit as they are adjustable. As for the rear you would have to change the leaf springs.
Steve23
Stephen
Maryland
Software Engineer
ooohhhhh okay I misunderstood. If they're the adjustable ones you can do that otherwise, without swapping out the fox ones I think your only option are strut spacers
Edit: lol or if I learned to read I'd see you said without replacing your current Fox set
Bludrok
Bludrok
Acampo, California
www.ranger5g.com
I read on here that they aren't adjustable. I can't verify, because I don't have the truck yet.
Bludrok
Bludrok
Acampo, California
www.ranger5g.com
No worries, lol. Happens to all of us.
It should be adjustable period the only part that would be adjustable is the preload for the springs and that's it. As for the valve adjustment yeah unfortunately that's not adjustable unless you had 2.5
TBR17
Murphy North Carolina
Stock 2.0s on a Tremor have no ride height adjustment. In order to get more lift without replacing the 2.0s you'd likely have to do a spacer above the assembly (leveling kit). Not sure if I'd take the assembly apart and gain lift with a different coil in the stock 2.0. If you want 3"+, you could replace the fronts with 2.5s which can be 3" + and add a 1" block to the rear or add a leaf.
Fox 2.5s front and back, replace the control arms and leafs for not much more than what you spent on the tremor package.
or
Lawdawg
Ryan
2021 Ranger Tremor
Steve23
Stephen
Maryland
Software Engineer
If you go with a kit with new Upper Control arms, make sure they are compatible with your truck. Most, if not all of the Tremor's have cast spindles and not aluminum. Only ones I've seen compatible are Camburg and APG. If you look at ICON kits with upper control arms, they will state for aluminum spindles only. Hope this helps...
Camburg Ford Ranger 2wd/4wd 19-21 1.25 Performance Uniball Upper Arms | Camburg Engineering
APG – Engineered for Adventure (automotiveperformancegroup.com)
^^^ This for sure. A good many people didn’t realize they changed the UCAs mid model year
