Manual Trans Swap MT88
Av8or1
2022 Explorer Timberline, 2023 Ford Mach-E GT
Alright since this hasn't been done before and it seems like there is a LOT of interest, I thought I would at least draw up a blueprint for how to do it based on what I currently understand. I will add to this thread as I learn more and I encourage anyone else that's ready to undertake this to share details as well.
Since I think this thread will be looked at for a longtime to come, let me do a quick little intro. I'm an Automation engineer (think robots) working for a small integrator that does a fair bit of work with Ford. My 2019 FX4 Lariat is the first one my dealer sold, I bought it in April of 2019 and have put 55k mostly trouble free miles on it since, as far as styling goes I don't think there is a better looking truck on the market (no not even the 6g ranger), but the only downfall to it in my mind is the lack of a manual transmission option. I plan to eventually swap in a Bronco Getrag MT88 7 speed manual transmission into the Ranger, but first I either need to have my 10R80 fail, or finish up my project off-roader.
I also have a 1997 Land Rover Discovery that I bought without an engine or transmission and am in the process of putting in a 2.3L Ecoboost + Bronco MT88 Transmission. This is chronicled here:
https://www.ranger5g.com/forum/threads/2-3eco-in-a-disco.28883/
Below is going to be a parts list, as well as annotations of what needs to be done for installation. I will highlight what I do not yet know, but I also aim to dispel a lot of the misconceptions about this transmission as well as swapping transmissions in modern vehicles. Some of these tasks can be done while the vehicle is still drivable to minimize downtime. To keep this thread readable, I will post pictures in another post. If I didn't have to purchase an item, I won't have the part number, but will call that out. I am not associated with any of the companies for parts that I am listing, this is simply a list of how I plan to execute this project.
Here we go!
Transmission:
Getrag MT88. I would encourage you to purchase one from a junkyard because it will come with more components. Mine came with the full clutch assembly, as well as the shift cables, and came out of a Bronco that was rolled with 200 miles on it, so it is essentially new. These transmissions aren't super common so you may need to be patient. This is a cable shift transmission so the shifter in vehicle is attached via push/pull cable to the transmission. This has the big advantage of giving a lot of leeway in placement.
If your transmission didn't come with shift cables, you can buy them from Ford (you can look up the part number), or purchase a push/pull cable from McMaster-Carr and a 10mm ball end. The Rod ends you connect to on the transmission are 10mm balls.
The transmission will bolt directly up to the 2.3L ecoboost engine, as well as the stock transfer case in the Ranger. I will confirm shortly, but I believe the overall length of the transmission is nearly identical. You will need a flywheel and a clutch from a Bronco if your junkyard trans didn't come with one. You will also need a pilot bearing for the 2.3L ecoboost. All 2.3L ecoboosts are able to accept this pilot bearing. You will also need to remove and cap off the transmission cooler lines for the automatic from the Ranger.
Bronco MT7 Getrag MT88 Transmission: Purchased from Junkyard
Pilot Bearing: D4ZZ7600A
Clutch Flywheel Bolts: 8G9Z00812A
Shift Cables: (Came on my junkyard transmission)
Clutch & Flywheel: (Came on my junkyard transmission)
Bell Housing Bolts: https://lmr.com/item/LRS-7007AHDW/bellhousing-hardware-kit-10r80
Clutch:
All of the clutch pedal work can be done while the vehicle is still driveable. I selected the Bronco clutch pedal because I know the master cylinder and connections are appropriate to the throwout bearing on the transmission. You can choose to fit a different pedal at your own risk. This portion of the project will require custom fabrication. The clutch pedal is very large and will need to be cut down and custom fabricated to fit the mount into the ranger, and then the pedal will also need to be cut down to fit properly. An oblong hole will need to be cut in the firewall to pass through the clutch hosing & grommet (PN Below). On the Bronco this connects into the brake fluid reservoir, however I will be using an independent reservoir out of simplicity. I have included the part number for the fitting to connect the reservoir directly to the Ford clutch hosing. It is theoretically possible to use the T6 overseas ranger clutch pedal, but I do not have knowledge of this or modifications required to make it work with the Bronco Trans.
Bleeding the clutch is done on the fitting that immediately protrudes from the transmission. There is a small barb fitting on it with a rubber cover.
Clutch Pedal Assembly: MB3Z7519A
Clutch Hosing (reservoir to clutch pedal): MB3Z7T504A
Clutch Hosing (Clutch Pedal to transmission): (Came on my junkyard transmission)
Clutch fluid reservoir: https://www.summitracing.com/parts/WIL-260-12697
Clutch fluid reservoir fitting: https://www.summitracing.com/parts/VPE-11266
Shifter:
There are several compatible shifters for the transmission that Ford sells due to different trim levels in the Bronco. I just purchased the one that wasn't backordered, but any of them will do.
Yes you will have to hack apart your center console to make this work. This will require custom fabrication. I would then recommend getting a laser cut, or 3D printed panel to overlay over the center console that is cut apart to make it look nice again. You will need to remove the existing shifter, and make a hole large enough for the shift assembly.
Part Number: MB3Z-7210-V
Be sure to mark on the shift assembly and transmission what orientation the cables need to go in to make sure this works properly. There are two levers on the transmission, the big silver one is for left/right on the shifter and the black one is for front/back. You can spin the input shaft and select the gears by hand with the transmission out to understand which gear is which and then deduce which direction the cables need to be mounted. Reverse is of course the most obvious.
Electronics:
I of course have not done this, so there are some questions to be answered in the electrical realm.
Okay so here is the part that is going to both be the trickiest but also has the most misinformation. Yes it is a modern vehicle, but no the transmission is not integrally tied to the ECU. The MT88 transmission also requires NO electrical inputs to function properly. After doing this swap, you will almost certainly get a check engine/transmission light, but that does not make the vehicle undriveable. At the time of writing I do not know what is required to make that light go away. I also do not know how to get the vehicle to register that it is in reverse.
The vehicle DOES require it to be in park to start the engine so you can swap this signal with the clutch depressed sensor which is built into the Bronco clutch pedal. Or you can maybe jumper the signal out somewhere.
An alternative would be to get another ECU. 2.3L ecoboost swapping is becoming very popular and there are several ECU's out there, many of which are compatible with manual transmissions. The one I purchased for my project is from Ford and comes with its own clutch depressed switch.
https://performanceparts.ford.com/part/M-6017-23T
I'm hopeful that this can be a collaborative project for all of us to learn and figure it out to make our trucks the absolute coolest on the planet :).
JasonTremor
2021 Ranger Tremor XLT
On the electronics front, I'm curious how ford enabled the anti-stall and rev matching on the bronco implementation of the manual transmission. If someone had access to HPTuner files for both a manual trans bronco and an automatic ranger, you could compare and reverse engineer a solution. Not certain if ford uses a separate TCM these days in addition to the ECM module. That used to be all in the ECM.
ControlNode
Eastern NC
Computers
I know when I converted my B20Z CR-V engine from auto to manual, to not gets codes, getting a manual ECU was the way to go. It was older so it also had coolant lines through the throttle body on the auto.
I'm sure there is a way with the Ranger, but I'm not sure what reprogramming or configuration changes may be required in the modules. But, good luck and keep us posted, while I plan to leave my current Ranger auto, I would love to help someone convert one.
JasonTremor
Historically, an ECM mapped for automatic transmission was easy to use for a manual swap. You just turned off the automatic transmission control by disabling a few options. Not sure it is that simple in the current generation ECM though. Haven't laid eyes on a newer generation directly. I would definitely see what configurable options are there prior to running the standalone unit. The BCM is coded to the ECM and custom tuning on the original ECM would likely be the happy path to retaining all the functions controller by the BCM. (Keyless entry, PATS, dash and infotainment function, restrain system/airbags, etc...). Setup an account on the HPTuners forum and see if someone did this with a mustang. Believe the forum account is free, or used to be. I know the mustang crowd has been swapping automatics to manuals for years.
Pebkac
Justin
Oklahoma
Mercedes C300
Mech Engineer
For programming information you might check with the YouTube channel and contact info for
Big Ben's Cars & Cycles
[email protected]
He's done many 2012-2018 Focus swaps to manual from dual clutch auto and programmed modules to make everything work with Forscan. Apparently even able to swap 6F35s etc into Focuses.
Might be a good source of help/advice in that area. They also run a manual swap Focus Discord server.
Dereku
Chicagoland Area
I did confirm both transmissions are the exact same length. Mechanically, this would really be a very easy swap.
Im not too far away from you. I volunteer to be a test subject. Then I won’t sound like an asshole when people ask to use my truck and I say no. Because 90 percent of people cant drive a manual lol.
fjwlobo
Fred
Brooklyn Park, Maryland
2020 Ranger Lariat FX4 SCREW
I've said it before and I'll say it again!!!
Manual transmissions are the new theft deterrent ??.
Better than the Club ????
Dereku
Chicagoland Area
Only in the USA tho. Rest of the world gets what the extra pedal is for. But completely agree. I want my kids to drive a manual too. Good luck texting and driving.
I knew I was doing something right! Both my kids, one boy and one girl, drive manuals exclusively.
When we were in Germany a few years back, while we walked down the street. I would check out the cars parked. They were almost exclusively manuals. Another couple on the tour came over early and said they had a hard time getting a rental car with an automatic.
Dereku
Chicagoland Area
Good dads teach their kids to drive stick.
