Rp930
Your FP tuner will only work with your truck as far as I know.My truck does the same thing. Vehicle speed dropping, driver is inputting more throttle to the vehicle, and while continuing to lose speed the whole truck vibrates because it is in too high of a gear. It's pretty much the definition of lugging. Typically, this occurs when not driving like a madman, for me when trying to go about 10-15 mph in the neighborhood (up a slight hill) or cruising around a campground or trailhead. It is not normal vehicle behavior unless you have a Ranger, then it is just considered a "truck thing". You can remedy the improper shift points by installing a tune. Chances are if you are experiencing the lugging you probably keep things easy on the throttle most of the time. If this is the case, another benefit of the tune is you will increase your gas mileage. My theory on this is that I don't have to put the pedal to the floor to get the truck to shift where it should be. It really does make a world of difference. I recently removed the tune on my truck as I'm going to follow the best advice in this thread and I'm getting rid of this truck. Once I removed the tune, shifting returned how it was and the lugging returned. I kept the tuner plugged in so that I could monitor RPMs and temperatures and noticed when it is happening the truck is down around 1100 RPMs. Just some productive feedback from someone who actually owns and drives the same truck as you.
The UAW strike has my replacement vehicle delayed for an undetermined amount of time, so I have been hesitant to start selling all the stuff on my truck. But, keep an eye on the marketplace if you are interested in a Ford Performance Tuner.
