Leveling kit
EDSEL FX4
JIMMY
BETHLEHEM GA
2019 RANGER XLT FX4
BMW PARTS DEPT
First off I am new here, you can get a lot of knowledge about everything Ranger. My question is what do you all think is the best budget level kit. I just got a 19 Ranger FX4. I painted the tow hooks this past weekend and think they came out great. Now I want to level it. What kit do you like. Here are a couple of pics of the hooks..
lawrench
Harry
2019 Ford Ranger Lariat SCrew FX4 Lightning Blue
I went with the Ford Performance kit. I had a warranty and had the dealer install them to keep the warranty. I am happy with it, and it did level the truck and improved the ride as well. It also stopped the dolphining the Ranger does with the standard shocks.
EDSEL FX4
EDSEL FX4
JIMMY
BETHLEHEM GA
2019 RANGER XLT FX4
BMW PARTS DEPT
That's a pricey kit, Although if you're going to do it you might as well spend a little more and do it right.
I went with the RC level kit. It's $100 and I had my local shop do the instal. It's been on about 2.5 years now and when I bring my truck in for an oil change they check everything and re-torque if necessary. It still has a little rake (about 3/8") but looks level by eye.
lawrench
Harry
I'm starting to like the 70 bags of sand in the bed idea. Lol.
I am fortunate that the wife works for an Auto Group that has a Ford Dealer, and she gets an employee discount. It is not as good as one might think, but it is something.
Living The Dream
Welcome fellow Georgian!
I'm running the 2" Zone leveling kit which is a bit different than the typical spacer lift in that it has a thin space (approx 1/4 inch) and a collar that compresses the spring.
I got mine at Stage 3
This gives you the lift and also firms up the front end to help with the porpoising that these trucks can do when stock.
Add a pair of Bilstein or Eibach shocks in the rear and you will be amazed at the improvement.
Here it is running 265/70/17 tires.
JesseS
Jesse
NorCal (Roseville)
Nice job on the tow hooks, only thing I will point out is the first time you use them you will have to repaint. As for leveling I went with the Eibach Pro kit, very happy with them, but most of the kits out are better than the OEM suspension.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
I'd go with BDS or Truxxx.
BDS 2" uses both an upper and a lower spacer and includes new rear shocks.
I had Truxxx spacers on my old Sport Trac and they are a quality unit. They have 1.5", 2.5", and 3.5".
Both are around $185.
Here
XLT
Plus one to Dave’s recommendation on the Rough Country 2-1/2ā€ Level Kit. I had one on mine for a year before switching to Fox Performance. Inexpensive, easy enough to install, no issues, lots of room for taller tires, great stance. If you carry a lot of weight in the bed often or plan on installing a topper, you should consider a 2ā€ kit.
apotocki
Alan
Rochester Hills, Michigan
2019 Ranger XLT
Network Force Analyst
Plus two to Dave’s rec.
I’ve had the RC 2.5 level for 2 years now with no issues/no complaints.
I don’t do a lot of off road but have done some with no issues.
It’s all about what you plan on doing with the truck and your budget. If you off road quite a bit and have the funds you might consider another option like the Eibach, Fox or equivalent….but I’m happy with just the ā€˜basic’ level.
Now…..with that said - I would also consider changing the rear shocks regardless. That makes a world of difference eliminating the bouncy/floating feeling,
Colo_Ranger
I love my Eibach Pro Kit. Reach out to Stage 3 Motorsports here and they will take care of you too. The ride is fantastic and is adjustable from 0-3". The install was not difficult, I'd say a 3 out of 5 on the difficulty scale.
matt_martin8
Maine
I’m running the Pro Comp 2.25ā€ leveling kit. I’ve had it on for five months now. I did swap out the stock crash bars for the Pro Comp high clearance crash bars and put 1.5ā€ wheel spacers to clear the 285/70/17s. There is roughly a 3/4ā€ rake but it does ride a little rougher. I have been debating on getting the Fox 2.0 shocks from ford to have it ride better.
CFLRANGER
Bobby
2020 Ranger
Has anybody had an issue with steering being to one side a tad after leveling kit install?
