Just updated to Sync 3.4 on my Ranger 2019
SafetyDan
Dan
Oxnard, CA
Ford needs to send a Forscan device to all Ranger owners, and include one in future sales. ;-)
Czaplewskin
Nick
MN
2019 Black Lariat FX4
Seriously. This can't be that hard to fix? What am I supposed to do in the meantime? Not touch my climate? kthx.
I also lost climate controls, but I don't understand why everyone is so upset. I have yet to find anything that I can't do on my physical buttons.?!?!
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
You can't change the vent selection (auto uses a mixture of head and feet), you also can't enable/disable DUAL mode (as soon as the passenger climate changes it is in dual mode).
Those are the key things I've found you absolutely *cannot* do without the SYNC UI.
treimche
Troy
FORT MYERS, FL
2019 Ranger SOLD. 2005 S2000
Accountant
Show us a video of how you change your vents to blow air through the windshield defrost vents and floor at the same time, without using the climate controls on the SYNC screen. Then another video showing how you turn off the dual climate control mode after your passenger changes their temp to something different from the driver.
treimche
Troy
FORT MYERS, FL
Accountant
Or they could just pull their heads out of their asses and create an update that actually works.
GT5050
Greg
Miami
2019 Ford Ranger XLT FX4
Downloaded mine today and installed. Other than the looping finish/restart sequence all went fine. Nice to bring my Ranger up to 3.4, I’ve gotten used to it in many of the other vehicles I drive, so the 3.3 felt dated.
Mine is a non-Nav version, and I have zero issues with climate. Full functionality, including the “dual” section as well as heated seats on the home screen and in the “additional controls” accessed from the menu button in climate
GT5050
Greg
Miami
My update had all of the above
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Quite a few have, but many have been plagued with the issue that I have, where the climate UI is completely missing with the 3.4 update.
GT5050
Greg
Miami
Yep. But some are saying that even if you get the climate UI you don’t get full functionality. On mine everything works as it should. Don’t know what would be different but UofM probably does
pgilbert
Stoughton MA
Program Coordinator
Through all of this, I did find that holding in the auto button on the panel for a few seconds will take it out of dual mode! A lot easier to use sync screen now that it has been restored!
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Correct, holding auto *should* restore HVAC to the stored "preferred" setting for the currently in use key. My mustang had the same feature and it was so hit/miss on when/whether it worked I almost never used it after a while. I don't generally trust that it's going to work now either.
Paul Moline
Fairfax Station, VA
2019 Ford Ranger Lariat SuperCab 4X4
I checked my USB this morning, this is what is on it, no XML file to signal it actually finished. It ran for over 2 hours I guess I pulled it early?? Seems to me it was just looping.
contents of interlog... folder all exactly the same.
UofMEngineer
Yep, they still haven't added the Delay option, so if you don't pull it when it restarts itself it just keeps running the XML tool.
weasel1
Pembroke, Ontario
Nuclear Operator
If pulling it out after two hours is to early, I need to have a chat with my wife.
koly
Ontario
The XML file should be in your SyncMyRide folder.
