Jiffy Lube Can't Access Ranger's filter
GitRDone
Andrew
Orlando Fl
2020 XLT
Real estate management
I do my own, but my friend Tommy was a faithful customer until after his last oil service by JL (and I do mean LAST). He spotted a small oil spot under the truck and crawled under to discover a rubber drain plug instead of the factory unit. Turns out JL had stripped his drain plug and replaced it with a "universal" rubber plug without telling him.
Progeny2021
Charlotte, NC
Fritz
St.Paul
2019 XL
Me and a couple buddies basically ran the local JF when we were in highschool. Our manager was a meth addict who was infrequently there.
I do my own oil changes unless I'm halfway across the country and really need it.
brroberts
Randy
Overbrook, KS
audio / semi retired
Time to drive there, time home, plus 20 minutes in line. I’d have found the time to do it.
mtbikernate
NC
2019 Ranger XLT 4x4
I've always been leery of those places. It's where my wife always went and I couldn't convince her not to. Until one of them failed to adequately secure her oil drain plug and all that fresh oil drained into the driveway.
I used one for my state inspection once when I lived in TX. They lost a brake caliper bolt after checking my brake pad wear (I guess), and by the time I found the source of the noise, the other caliper bolt had nearly worked itself off.
I don't enjoy working on engines anymore, so I'd rather pay someone else to do it. But I'd DIY before having a quick lube place do the job.
You could've done your own oil change in that 20 minutes easily...the last time Jiffy Lube changed my wife's suv, they left the oil cap off sitting on the engine...
MountainGoat
Missouri
2020 Ranger XLT Sport 4x4
They might be complaining about the initially installed factory filter. It is impacted on very tight and you need the right kind of wrench. After that though the rest come off by hand.
SigOris
Greenwood Maine
Retired DoD EE
Progeny2021
Charlotte, NC
JimmyFD43
Franklin nc
2022 Ford Ranger XLT
Question...What is the difference between the "initial" factory filter and a new OEM ford replacement? I just had my mechanic change mine at 5000 miles on my 2022 and they looked identical.
MountainGoat
Missouri
It's the same filter just the first one from the factory was super tight and I couldn't loosen by hand so I needed a specific 3-claw wrench to get it off. My regular oil filter wrenches did not work.
wow inspections must be strict in the area you are! ive never had inspection folks check much more than lights, obd and for a muffler .
Progeny2021
Charlotte, NC
