Is there an official ford guidence for "Approved tire size"?
ThatPRDude
Franco
Puerto Rico
2021 Ford Ranger XLT
I'm part of a local ranger group. A member is having some issues with his drivetrain and took it in for a diagnostic, the ford tech mentioned that since his tires are different from stock if the problem is in the differential it won't be covered by warranty.
I've searched for an official guidance and come up with nothing. So, is there an oficial guide for "aproved" tires sizes?
The Ford Performance Tuner allows you to change the tire size. It is limited to a certain size, although I cannot remember what it is.
I would say that is the largest recommended size.
CO2Ranger
Hi Franco,
The approved tire is on the left door jamb label along with recommended tire pressure etc.
ThatPRDude
ThatPRDude
Franco
Puerto Rico
Hi Franco,
Thanks, I figured.
My truck is still stock except for the grill, was just looking to see if there was any other information out there.
Bob902
St. Louis
RETIRED!!!!
If they are denying warranty claims because of changing tire sizes, nobody around here should be getting warranty work done.
SigOris
Greenwood Maine
Retired DoD EE
Hi Franco,
So a question Phil.
Does that stated PSI the same for all tire MFG’s given the same tire size is used?
in my case, I went from OEM Hanooks to BFG KO2’s but same size.
thanks in advance
Rp930
Denver
I would not assume that to be the case.
mgallo13
Matt
Neptune City, NJ
2015 MM Focus ST (sold), 2020 MM Ford Ranger XLT
Financial Controller
Hi Franco,
Hypothetical for you Phil- how could Ford deny a warranty claim on a differential for example, because I went to a 33" tire with a total increase in unsprung weight 10lbs/whl, when the truck is rated to tow (IE addtl unsprung weight...) 7500 lbs from the factory?
I guess what i'm asking is how is the larger tire any more wear and tear on the vehicle than if I maxed my truck out every day of its life, whether it's payload or towing?...
Edit: math.
stock sport tires 36 lbs + stock rims 27lbs = 63 lbs
wildpeaks 50lbs (p rated) + KMCs 23lbs = 73 lbs
Jason B
2021 XL STX SE 4x2
machinist
Edit: math.
It's not about weight of the tires, but the additional rotational forces required to turn those tires,
as well as increased stress on suspension parts.
philanderer
land of oz
'22 ford ranger cactus scab
so the tremor comes with 265/70/17? so i should be ok putting this size on my xlt as far as warranty issues are concerned?
