Installed PPE transmission pan
gwhalin
Greg
New York
I considered replacing mine but I have a steel skid plate covering the entire plastic pan. That makes the only benefit being a drain plug and more capacity. Still might someday just because I like tinkering but definitely lower on my list
Shaneb72
Shane
McKinney Texas
2021 Ford Ranger XLT FX4 302A Oxford White
Registered nurse Workers Comp Case Manager
I added the PPE pan to mine as well and installed a "Glowshift" brang temp gauge in the threaded side port. It seems to have dropped my trans temps about 8 to 10 degrees, and in the Texas summer you need all the help you can get lol.
maxbottomtime
NE OH
2021 Ranger XLT SCAB 4x4
Old Red Replacement
Ernie
Crystal River,Fl
2020 Ranger XL 4x4
Retired OTR Diver/Maintenance Mechanic
Old Red Replacement
Ernie
Crystal River,Fl
2020 Ranger XL 4x4
Thank you Glowshift has amazing tracking and order follow up.
I have everything now( pan, fluid, 12 V transfer pump, filter)
ordered pan gasket and filter O seal just in case, were you able to
reuse yours.
Located micro 2 switched for gauge, taping headlight feed wire,
Whoever put that dipstick cover plug there and loosely fit
19 mm size really don’t want us to do this upgrade.
thanks again.
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
Where did you mount the glowshift gauge?
gwhalin
Greg
New York
reuse yours.
thanks again.
What pump did you buy?
Dereku
Chicagoland Area
Ok that is sexy. Bet you look at it every oil change now!
Old Red Replacement
Ernie
Crystal River,Fl
2020 Ranger XL 4x4
Got the pod to put it on dash left side,
Have not done it yet.
Finding micro 2 fuse tap, ignition controlled fuse, 35-37 small ones in dash fuse panel left side bottom.
thelight for it is disposed to be self dimming and needs switched control,
Headlights are on relay, going to run wire
From bulb feed?
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
Shaneb72
Shane
McKinney Texas
Those are pretty tall.
Are they hard to see over?
They look taller than they are, they are really about 3 1/2 in tall
