How much lift up front is reasonable? Is 3" the limit?
I was able to get mine aligned when I took it into a shop after I installed my new front springs and shocks. So either I was lied to or somehow specs vary from parts to parts for assembly? lmao
Are you at 3"?
2" was plenty for me. Fit 33"s with crashbars intact and that's enough clearance for me.
RangerPNW
Thomas
Santa Fe, NM
I'm up 2" over stock up front but I'd like to go a little more.
Is 3" too much for the geometry? The Fox 2.0 says 2-3"
Part of the reason Fox doesn't recommend higher than 2" with their shocks is you still want to have some droop left in the travel for stuff like pot holes. While you can go higher, you're sacrificing a lot of ride comfort and potentially handling in the process. Not to mention as others stated you're getting pretty close to the safe limits on your CV angles assuming you're 4wd.
Mad440x
Michael
East Tn.
2021 ford ranger
Construction. I work!
I put 3” and could not get alignment to work. Cost me 2 tires while I waited for new parts.
went with 2.4” bilstein/Arb 5100 coil over. And 1” block and rough country shocks.275/65/18 tires. Which are 32” ish. Works great. Tiny bit of rub on crash bars but will be removing those.
OFC Ranger
Jack
ZR2
Right same as mine except I did 2.5"
Correct. So like I said, either I was lied to at alignment shop (but they gave me the before/after spec sheet) or I gotten the equivalent of some golden ticket willy wonka suspension components out of the factory.
Mentioned above, been running this close to a year, tires appear to be wearing normal as well.
"Close enough", checked...?
cclayton
Collin Clayton
Bilstein 5100s set at 2.5” with 285/70/17 tires and 17x9 wheels with +1 offset. Crash bars are removed.
Looks like there is still a small amount of rake, like .25”? I haven’t measured yet.
N84ST
Nate
MA
Ranger
Well how much lift do the Rocky Ridge Rangers get? You can get them from the dealership lifted quite a bit.
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
You do not want the half ass lift they put on their trucks
