If you're not confident in your wiring abilities, then just get a few battery powered pod lights and mount them in the bed. Sometimes you can even turn them on with your phone. You'll have to remember to charge/change batteries, but it's a simple setup with zero risk of messing anything up on the truck's wiring.I want to wire bed lights so when I press the cargo switch both the factory cargo lights come on and the led bed lights. NOTE: I'm not very handy with wiring so if possible make it as easy as possible but I'm willing to try anything.
It is against the law for a manufacturer to void the warranty on a product. Now if you wired the bed lights to the cargo lights and the cargo lights stopped working Ford could deny a warranty claim on the cargo light but nothing else would be impacted. You could potentially wire up something incorrectly to the upfitter switches and ruin the module under the hood and have a warranty claim for that denied.I personally would not, as it may void the factory warranty. I instead wired mine to the factory upfitter switches (not all models have these, mine is an XLT Tremor and it does) to keep the warranty intact.
I believe the factory upfitter switches are the only places you can wire bed lights and keep warranty, only other way is to use the Ford Lumen kit as it’s got an approved harnesses.
My dealer said the cargo light relay isn’t designed for aftermarket accessory loads but the upfitter switches are fused and rated for the current (and then some) so overloading it won’t blow up anything else.It is against the law for a manufacturer to void the warranty on a product. Now if you wired the bed lights to the cargo lights and the cargo lights stopped working Ford could deny a warranty claim on the cargo light but nothing else would be impacted. You could potentially wire up something incorrectly to the upfitter switches and ruin the module under the hood and have a warranty claim for that denied.
Most of the led strips the folks have added on here draw like 2 amps or less. But of course the upfitters are the safer route. I haven't seen anyone report an issue using that circuit though.My dealer said the cargo light relay isn’t designed for aftermarket accessory loads but the upfitter switches are fused and rated for the current (and then some) so overloading it won’t blow up anything else.
Just repeating what I heard from my dealer, others may be more “mod friendly”
The cargo light is not controlled by a relay, as best I can tell it's a FET controller in the BCM. And from the reading on those, it appears they have over current protections as well, so if too much load is drawn through a FET that circuit is shut down to protect the BCM and other loads fed through the BCM.My dealer said the cargo light relay isn’t designed for aftermarket accessory loads but the upfitter switches are fused and rated for the current (and then some) so overloading it won’t blow up anything else.
If you happen to damage the FET controller in the BCM, or the protection circuit fails to shut it down and damage reaches any other electrical systems powered though the BCM, warranty on those things could be denied as well if they show the source of what caused it was the wiring you did.It is against the law for a manufacturer to void the warranty on a product. Now if you wired the bed lights to the cargo lights and the cargo lights stopped working Ford could deny a warranty claim on the cargo light but nothing else would be impacted. You could potentially wire up something incorrectly to the upfitter switches and ruin the module under the hood and have a warranty claim for that denied.
