Gas tank size - 18 or 19 gallons?
omniphil
NH
2021 Ranger
Hey Guys,
Out first tank with the ranger took 17.1 gallons when the gas light came on. Usually there is a larger buffer between gas light and empty.
All the Ford literature says 18 gallon tank, but interestingly enough in the FORscan software the default says 19 gallons...
So 18 or 19?
Mine is a 4X4 XLT - I think they are all the same on every version though...
Zvedza
'21 Ranger Tremor, '04 SVT Lightning, '16 ZX-10R
Hey Guys,
So 18 or 19?
I read somewhere its 18.8 gal
Edit: Found where i saw it
http://www.f150hub.com/trucks/ford-ranger.html
omniphil
NH
2021 Ranger
Interesting.. That would certainly make more sense as usually you have around 2 gallons left when the gas light comes on in most vehicles...
Just curious what other folks are finding as far as how much gas it takes when you are down near empty. I'm sure someone has run it down to 0 miles and then filled up. I bet it takes over 18 gallons in that case....
Motorpsychology
Prescott, WI
Vagabond
Hey Guys,
So 18 or 19?
From your Owner's Manual:
TomC
Florida and North Carolina
2020 ranger lariat supercab FX4
Family vehicle MX officer
From the manual. And from not paying attention, but still got to a station.. left wallet at home, used the $20 I had in the console.
nevada.tracy
Hudson Falls
2020 ranger
Hey Guys,
So 18 or 19?
I actually have put in 20 gallons of gas a couple weeks ago in my 2020 ranger xlt. I did drive it for a while with the gas light on. But was amazed the gas pump said 20 gallons.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
That's what happens when you fill it to the top of the neck, or as close to that as the pump will allow.
towpro
Central Florida
22 Lariet F150
actually those pumps are calibrated before being inspected and sealed by the county or state.
We had a 5 gallon can that was tapered at the top with a glass bubble that showed you exactly how much was in the can. After pumps were repaired or replaced we needed t re-calibrate the readout so it would dispense more then 4.5 gal (90%) but less than 5 gallons (100%) so we were within the 10% range. this was to compensate for the thermal expansion characteristics of gasoline.
we were buying fuel at 95deg F from the refinery, but when transfered to underground tank it would cool to about 58deg F and the fuel would condense and he would loose volume.
BlackRanger01
Larry
New York
2021 Ford Ranger Lariat Super Cab 4x4
IT
I read it was 18.0 GAL somewhere and on my first tank refill, it said 20 miles to E and i filled up - 17.98 GAL. I freaked. Now i know :)
VoodooRanger
Joel
Miami, Florida
Whatever it is, it’s not enough.
Motorpsychology
Prescott, WI
Vagabond
Where can you find such information? This is astounding! And in written form, no less! Amazing!
Well... Above the attachment I typed, "From your Owner's Manual."
Seriously, You can download it here. Saves me a trip out to the garage.
