fumoto f107SX oil drain valve
gwhalin
Greg
New York
Did you use any aftermarket washer?
EJH
Ed
Subarus, 2021 Ranger
I have used these valves on my two Subarus for years. Really easy oil changes, no issues.
Now if there was a way to relocate the Ranger's oil filter somewhere actually accessible ;)
JesseS
Jesse
NorCal (Roseville)
That would be fine on a street truck, but I do desert running a lot while RV'ing and would worry about something taking it out. Would suck to lose all of my oil 20 miles in the boonies. I use the normal long nipple valve with a short vinyl hose tucked up under the skid plate, easy to pull out when needed, and safe.
RedlyrsRevenge
Sean
Fresno, CA
21 Carbonized Gray SuperCab STX FX4
MH/FE Parts Salesman
I had one on my Crosstrek and it make oil changes a 10 minute job. Good to know there is one that works for the Ranger as well. I have free oil changes for life but, I probably will be doing some of my own.
Reactions: EJH
4rd SVT
In da Driver's Seat
Ford SVT, Ford Performance, Winter-Beaters
What's the part number you are referring to?
4rd SVT
In da Driver's Seat
I wouldn't need to install the Fumoto Extension/Adapter?
Which one would be the correct size for the Ranger>
Like ADP-104 or ADP-108...
FX4's skid plate protects that area...I attached a flexible hose for draining so I don't have to remove the plate when changing oil...
4rd SVT
In da Driver's Seat
Then you should be more worried about tranny cover. It’s plastic and if you take out a valve like this you can bet that will go with it! Sid said it, got a skid plate for that reason.
JesseS
Jesse
NorCal (Roseville)
OP has a 2019 STX, does that even have the skid plate? I was going by the photo, didn't look like it was protected that well.
Bungleflop
Christopher
San Antonio tx
2019 ranger 4x4 STX/2017 fiesta se
Us army infantry
No you only need that if you get the older version this one is great because it's two piece so the actual spout can point away from the pan as you tighten the issue with the older one is that the spout would hit the pan so as long as you get the f107SX you'll be fine
