Front Air Dam Removed
philanderer
land of oz
'22 ford ranger cactus scab
hate to revive a thread from the dead, but is the configuration up front the same on the 22s where i can remove the air dam?
u wish u could ride
robert
lakeland florida
19 xlt in blue
building maintenance
i believe they are the same!! ps its been 25k miles since i took mine off !Itossed the plastic park last years garage clean out.
Squatchranger
Orlando
19 ranger lariat
It should be, I would advise cutting and removing the outer sides and tucking the middle into the skid plate to eliminate the gap between the plate and bumper and somewhat smooth out the airflow beneath the truck
philanderer
land of oz
mine wont have a skid. still removable? will look like this 21
Squatchranger
Orlando
19 ranger lariat
Idk if you can tuck it if you dont have a skid plate there but you can take it off
you should be able to take it off regardless idk if you can tuck it if you dont have the skid plate down there is yours 4x4?
You can remove it but modding it to close a gap? No. The gap exists because of the skid plate and the skid plate holds the modified dam in place, using the tow hook bolts to pinch it in place.
docarter
Dayton
GA
Cadillac ATS; Ford Ranger
ADA
Did mine, looks way better and improves scrapping clearance for you offr roaders, only takes about 10 minutes with a small impact gun. If your truck is a daily driver for MPG i would leave it on.
I did a really rough trail this past weekend and never contacted the front airdam. The approach angle if you are being smart and using some off-center approaches is darn near 50-60*.
I don't think the airdam really impacts approach angle much, if all, since its closer to the wheels than the bumper.
philanderer
land of oz
again, my truck wont have a skid, as the one pictured in my previous post
philanderer
land of oz
it will be 4x4 but without a skid
Dairychuk
Dylan
Canada
2021 Ford ranger
I removed mine probably the 2nd week I had my truck (last july). I'm pretty sure it had a small effect on fuel mileage, but I doubt more than about 1mpg. I still saved mine and will probably look into reinstalling it for long highway trips.
Also one thing to note, you end up with a small gap between the bottom of the bumper and the front of the skid plate. I haven't fixed this yet, but I definitely see this as creating a small amount of turbulence over say, the FX4 where the skid plate comes all the way up to the front bumper. might be something to consider.
If I have a non fx4 ranger, am I able to install a fx4 skid plate and eliminate that gap? Do I need a different bumper?
Dylan, that depends on whether or not you have tow hooks. If you do, it’s easy enough. If you don’t it becomes complicated.
RangersLeadTheWay
GA
2019 Ford Ranger Lariat 4x4
I have a 4x4 and replaced the skid plate with the FX4 one. It did not require a different bumper.
