Free Sync 3 Navigation Map Updates (NA 1 18)
MJP
Lehigh Valley
2019 Lariat
Curious:
1) If I saved my info into ProCal in preperation for the Performance upgrade -> prior to updating to this latest 3.4, can I restore from ProCal or is this module not saved as part of that process?
or
2) If I saved my 'as built' information prior to this 3.4 update can I restore from that using FORScan?
My unlucky numbers:
Why are you saying your unlucky numbers, you have 0000 in the second field, I was told in a recent previous post that I would no lose the climate control on the screen.
Fjoyner
Forrest
Missouri
2019 Lariat 4X4, FX4, Black package
Retired Optometrist
You're looking in the wrong spot. See above msgs, but it's xxxx xx8x xxxx. Mine has the 8 in the unlucky spot, so it will and did kill my climate controls.
Fjoyner
Forrest
Missouri
Retired Optometrist
That makes sense..
A bug in 3.3 that was fixed in 3.4 so when you 1st went to 3.4 the bug occurred and you fixed it. Since it was fixed reloading 3.4 had no effect.
Bug swapping...
MJP
Lehigh Valley
2019 Lariat
Thanks, so just confirming, my numbers are below, will I lose the climate control after the update, please let me know, I just want to be sure.
7D0-04-01000033000D1C
SandBaja
Larry
San Diego
2019 Silver FX4, 501A pkg, fully optioned,2012 Rubicon, 2017 Cherokee, 2018 Volt
Almost retired
You should be OK
Tra1969
2022 Ford Ranger Lariat Tremor 501A and Tow
Senior Manufacturing Supervisor
I have the same numbers as you do. Did you get it fixed after you updated?
Fjoyner
Forrest
Missouri
Retired Optometrist
No. I haven't found any method to either reverse it or fix it. I'll wait it out before I take it to the dealer, so currently, I'm waiting.
Fjoyner
Forrest
Missouri
Retired Optometrist
Yes. I'm certainly not the expert here, but your middle set is missing the 8, so you are golden.
Tra1969
thanks. I guess will just wait till till I see it’s been resolved. Thanks for the info.
VAMike
2019 Ranger Lariat SuperCab
I lost the climate screen, but I'm not overly bothered for now--it's always just been on auto anyway.
ABKsDad
Houston
So a strange thing happened yesterday while upgrading the maps. I had already upgraded the Sync to 3.4 the previous day but when I started the map upgrade it was almost as if as soon as I pressed the button to approve the upgrade that it felt like the system had turned the heat on. AC would not blow any cool let alone cold air. Drove home and around with the AC off and the windows down. Nothing I tried including a master rest would kick the AC back on.
Now I had been idling in the Texas heat for about 15 minutes prior to starting the process, so I am wondering if the AC just choose that moment to burn out.
Anyway the truck is now at the dealer with them hopefully finding out the issue and fixing it.
Jrye22
Jon
New Jersey
2019 ranger lariat
I seem to be having an issue trying to update these damn maps. I have version 17, downloaded 18 did the install had it come up as successful and restarted the truck like it tells you to and still have 17 . Called ford sync services and they tried to tell me 18 was no go so they released version 19. Started from the beginning freshly downloaded the “new” version and attempted again with the same issue. I am on sync 3.3 build 19052 cause they took down 3.4 anyone have some insight?
UofMEngineer
They should’ve told you that is a bug in v3.3. You may have the 18/19 maps installed correctly. You can verify via the diagnostic screen. Updating to 3.4 won’t fix that string until the next map install is run.
Jrye22
Jon
New Jersey
2019 ranger lariat
Gotcha how do I get to the diagnostic screen? And what your saying is once I can update to 3.4 rerun the map update so the number will change as well? I also lost my voice commands for nav only it seems like.
UofMEngineer
Correct on 3.4 and re-run. You’ll need to re-run anyway if voice isn’t working as the install didn’t complete fully. See other thread on that specific topic. Diag menu is hold down seek forward / right on the IP and steering wheel for 10 seconds, end speaker walk around, select APIM in upper left, IVSU Versions in lower right. For map you’ll see one 14G421 and one 14G422 (which ones depends on system language and the current location) if the map is fully installed. If you check now you won’t have a 14G422 most likely.
