FORScan Modifications
Fastfitzy
Casey
Colorado Springs, CO
I picked up a cheap adapter on Amazon, downloaded the software and went to town. I think it’s awesome. Turned off the double honk, turned off my seatbelt and start up chimes, fixed my missing climate controls (main reason) and a bunch of other stuff I can’t remember. A must must have for any ranger or f-series owner
07XLT
Ohio
2007 Ranger XLT 2020 Ranger Lariat
Information Technology
changed my sync3 boot screen from the oval to the Raptor Ford performance screen that makes me grin like an idiot every time I get in.
I'm also going to fix fastblink when my LED front turns get in
DFisher
Ohio
2020 Ranger XLT 4x4
There are a couple things I would like to tweak but aren't sure if FORScan is the right place. Hoping someone can tell me if FORScan is the tool for the job.
1) When in drive (D), if you push + once on the gear selector it displays the transmission gear scale on the dashboard display. This goes away every time the vehicle is started .Can something be tweaked so that it displays all the time?
2) HVAC fan speed. When using the HVAC on AUTO I feel the fan speeds are always too slow. I usually have to bump up the fan speed 2 or 3 times to get enough air movement. Can I modify the setting so that the fan speeds are greater with using AUTO?
Thanks,
geophb
Mechanical Engineer
As far as I know.
1) No
2) No
Forscan essentially changes module configurations/features that would otherwise be available in other vehicles (this is why its called "as-built" data).
It does not change the logic/programming of those modules.
jubreunig
Juergen
Tuscaloosa AL
Does anybody know if we can programming the front side markers as a flash light?
Hi Juergen,
You mean like on stepping out of the truck to see or blinking for a turn?
LRB45
LONNY
FLORIDA
2019 FORD RANGER
Is there a method to get all doors to unlock when you open the driver's door with the engine running? Or shift into park?
Gets irritating when I jump out at a jobsite and have to constantly go back to unlock so I can drop the tailgate.
Ace Holliday
Scott K
South Kalifornikstan
2019 Ranger XLT Super Crew
Hit the unlock button when you open the driver's door?
LRB45
LONNY
FLORIDA
2019 FORD RANGER
There's always one :clap:. I can't possibly be the only person that finds this irritating? Or am I?
Hows this instead.
Is there a method to get all doors to unlock automatically when you open the driver's door with the engine running? Or shift into park?
AutobotXJ
Ray
Volcano, HI
2020 Ford Ranger
Wildlife Biologist
I have this same problem! Get out with the engine running to grab something from the Bed or passenger seat and it’s still locked. It’s more annoying than an undampened tailgate for sure!
treimche
Troy
FORT MYERS, FL
2019 Ranger SOLD. 2005 S2000
Accountant
Hows this instead.
No there is not. I wanted the exact same thing and have never found a way to do it. I really wish it would just unlock all the doors when shifting into Park, that would solve the problem.
Rp930
Denver
I just set it not to lock to begin with.
