FORScan Modifications
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
I just installed bed power and lights off the stock 20 amp plug located behind the driver rear wheel. this come on when you turn the key and then Stays on for 2hrs (I'm told).
Does anyone know if forscan could make this power on with unlock?
Its a pain when loading at night to have to insert the key to enable the bed lights.
RobmJ
Austin
For anybody who made the change to show the speed limit signs you can also activate a chime if you go over the limit you have set. It's under chimes in the IPC module. Just enable it. I forget the exact wording but it is obvious which one it is. Also adds a "chime" check box to the setup screen so you can turn it off or on. Tested today and it chimes once every time you go over your set limit. If I have time later I will try to post pics.
Where do I find the IPC module? I’m not seeing it on FORScan
revbevis
Tom
Ava, IL
2019 Ford Ranger XLT SuperCrew Chrome Package
I’m curious to know if we can mod it to autofold the mirrors when in park or locked with the key fob.
You need to purchase the auto window and auto fold mirror module.
RNS
Randy
Manitoba, Canada
2006 Chevy Silverado,2011 Kia Soul,2016 Ford Transit 250,2016 Focus RS,soon to be 2020 Ford Ranger
Hey guys!
I have the Ford Performance Tune and wondering if I need to remove said tune before I use forscan???
I've tried but no luck with tune installed..
Tuner (crashed/screen stopped accepting touch) shortly after install and been waiting months for Ford to figure out how to get my stock brain back onto new unit!!
Mr.Scary
Ontario
2019 Ranger sport 4x4
Heavy equipment operator
Question for everyone I am new to forscan. I wanted to enable terrain management on my ranger along with a few things. So I connect to my truck today save a profile of stock config. And when I try to start a service action to get in make the changes it tells me I have to do a relearn because code p160a is present. So I do the relearn and it keeps telling me the same thing.
Any ideas to help me out.
FYI I do have a livernoise tune on my ranger.
Thanks
Adventure Ranger
Saskatchewan, Canada
2020 Ford Ranger Lariate Crew Cab FX4 Sport
Heavy Equipment / Truck shop Foreman
Corrected my tire size today = Speedo is 100% confirmed with 2 independent GPS units.
Set my heated seat controls up on the touch screen. Also set the start up screen to "Ford Performance" the Cobra is a pretty cool look as it starts up ! :)
Mr.Scary
Ontario
Ok sorted it out returned my truck to stock just in case. Will put tun back in tomorrow.
I did
off road screen
Off road gauge
Terrain management
Parking lights on with drl
Fog lights on with high beams
Fog lights on with turn direction
Global windows up and down.
Although I can’t get the global windows to work.
My truck is a 2019 xlt 4x4 sport pkg
Igor
Igor
Ontario (ON)
Ford Ranger 2020 XLT 4x4 Sport
How to do that? Or is thin in Wiki? I mean what's the code for this screen?
I did
off road screen
Off road gauge
Terrain management
Global windows doesn't work on Rangers, we don't have required door modules. There is an aftermarket module you can add to get global up/down and control with remote. Do a search on global windows, several threads.
Can be done from the APIM module configuration, select from list.
Mr.Scary
Ontario
Thanks big blue i did figure it was something like that. i work stupid hours so i don't get much time to search.
with the Terrain Management dose it need the Intelligent 4X4 enabled as well or is that something else all together for the lariat?
Adventure Ranger
With the latest paid version of Forscan it gives you the option to change the start up screen. There’s about a dozen options. I picked the Ford Performance not knowing what it was- now I really like it.
