FORScan Modifications
Bproctor
Bruce
Hickory, NC
2019 Ford Ranger Lariat 2WD
NC National Guard
No worries, these forums have given me the next best thing. With my sync 3.4 upgrade, I can at least get my nave on the right digital display behind the steering wheel.
Does your NAV on the right side of the center dash screen work properly with MAPs? Mine shows 0.0KM and 0:00 Time at the top, but the turns are correct. It works as it should while using the stock navigation.
d_ganggreen
No, mine is similar to yours. I think it shows difference in KM, but the time is still 0:00. The turns are accurate though and given in miles.
Andy
Andy
Do you get navigation on the right IPC screen with CarPlay or Android auto?
d_ganggreen
It is on the right for Android Auto. I have only tried Carplay in my wife's '19 Edge (sync 3.4) and it does not work.
I think I may have found the switch in Forscan to disable "Fake Engine Noise". It is in the ACM module as-built:
727-01-01 xxxx - x*xx - xxxx, Reduce the number in * by 2, If it was an A like mine was enter 8. If 3 make it 1.
Seemed to make a difference but it is hard for me to tell with my bad hearing and hearing aids. Need someone who notices the fake noise to try and verify. Personally I don't really mind if it's there or not. Just thought I'd pass it on to try. Didn't seem to mess anything else up.
rpeterson53
Richland, WA
2019 Ranger Lariat, 2024 Toyota Prius Prime
I added that a while back and it works fine. Seems to come on when the temp is under 39 or 40. I've had no issues with my clock after making the change.
I just enabled frost alrt function thru Forscan. Where does the indication of warning appear on the dash ? Sure seems odd that Ford would not have enabled this feature.
quangdog
Kimball
Meridian, Idaho
www.youtube.com
2019 Ranger Lariat FX4
I *think* it appears in the lower portion of the center screen on the Lariat, but I may be wrong about that. I enabled mine shortly after I bought the truck (in March) and it was cold enough here to see it show up like twice. It was not hard to find, and I noticed it immediately.
This is the first vehicle I've ever owned with a frost telltale - it's purpose is just to let you know that there is a possibility of frosty/icy conditions, right? (it seems it turns on when the outdoor temp gets below something near freezing ... like 36ÂşF or something.
It has been quite a while since I saw it, and I don't see it too often here - we don't get below 40 in the winter too much. But from what I remember, that sounds right and I believe it shows up anytime it is under 40 (I distinctly remember seeing it when it turned 39). It isn't hard to see for sure.
Porpoise Hork
Bret
Houston
IT
The traffic sign reading seems to be an active feature for the Australian market. It looks like the Ranger also has Active Parking Aissist.
The Traffic Sign feature is nice which someone has already found out how to activate. What about the Semi Auto Park Assist? Not that I would want it personally but is it Forscan possible?
https://www.rangeford.com.au/new-vehicles/ranger/features/
It'd be nice if they had included it on the NA ranger, but even if we found the correct code to turn it on, it wouldn't work. Ford's semi-assist parking has to be activated via a push button that is typically located near the shifter.
Since ours lacks this button, and likely the harness is different as well so even if the button were added in, there would be nothing to connect it to.
Hirnlego
SC
2019 Ford Ranger XLT 302A
Has Anyone verified this? I would have thought more people would have been inclined to know. I personally would like to eliminate the fake engine sound. Will have to check next time I fire up Forscan.
Ace Holliday
Scott K
South Kalifornikstan
2019 Ranger XLT Super Crew
I have never heard any fake engine sound track that I know of. Which speaker(s) does it come out of?
I can hear my exhaust note in the cab since I installed a Flowmaster 40 Series muffler though. Maybe even a little too much.
I have not seen anyone come back and verify this yet. I personally don't mind it if it is even there. Some people swear it is there and some question if it is or not. I know there has been a lot of discussion about it and how to turn it off. Found this switch in the F150 spreadsheet and passed it for someone who says the here and hate it to try
Again I don't really notice it or at least am not annoyed by it. some have said front door speakers, some say if they have added a sub they hear it from there.
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
I tapped into the door speakers for my sub and there's nothing there.
The mystery continues, AKA "Do We Have Ghosts" ?
