FORScan Modifications
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
I'll experiment and see which lines need changing and works. I added power folding mirrors from a Mondeo and did all the changes in Forscan in my Fusion. Should be a factory feature.
FLEngineer
Orlando,FL
2019 Ford Ranger Lariat SCrew
Lol thanks! But in fairness, I'm just testing the values that the F150 guys have found and they work for the most part.
Yeah, that was my plan as well but of course you need a truck in the driveway for that to work.
t4thfavor
Chance
I've heard they can get broken if there's ice on them and they try to fold. Just FYI.
Andy
Andy
I'll be trying out the auto folding mirrors as soon as I get my truck this week.
Issue is as @j0shm1lls mentioned to me is the absence of door control modules as this is where the f150 mirror folding command takes place.
t4thfavor
Chance
This also stuffs us for Global Open/Close Windows too...
j0shm1lls
Josh
SoCal, USA
www.youtube.com
It might just be that the support for them isn't integrated into Forscan yet.
j0shm1lls
Josh
SoCal, USA
www.youtube.com
For anyone that has an XL and installs LEDs in the rear turns, I THINK this should fix Rear HyperBlink for you, but I can't verify as I have the Factory LED rears. If anyone wants to test and report back I'll update the wiki.
BCM - 726-28-01 x0xx xxx xxx
j0shm1lls
Josh
SoCal, USA
www.youtube.com
I want to know how to disable the lovely engine soundtrack. Made any attempt at that yet?
This will MOST LIKELY be the fix for you.
ACM 727-01-01 xxxx x*xx xxxx
Tell me what value is in that * for you and I can tell you what to try.
For me, in a Lariat with the B&O system, it is currently an "A", changing it to "8" should make it go away.
A lot of the F150 guys just say to set it to 0, but that might mess with your front tweeters.
EDIT: I will not be held responsible if your Ranger explodes. kthxbai
Andy
Andy
Have you tried to disable the engine sounds on your truck yet?
j0shm1lls
Josh
SoCal, USA
www.youtube.com
Nah, it doesn't bug me as much as it does some. If no one else tests this, I may give it a whirl. I did it in my RS, but that was as easy as pulling a plug out of a silver box in the trunk.
EDIT: alternatively, if someone can get the wiring diagram for the DSP, look for the "ANC IN" wires, pulling those plugs out of the amp will also get rid of the fake sounds.
HoosierT
Tyler
Fishers, IN
ā€˜19 Ranger Lariat FX4, '17 Explorer Sport
LOL luckily there aren’t many rangers on the road so if my truck explodes, it’ll be fairly easy to find you. Haha seriously though, I’ll hook up tomorrow and let you know what value I have. I also have a Lariat with b&o, blown speaker and all. That’s why I’m so excited to disable it, even with music off, I still enjoy the raddle of the blown speaker as the system pipes in engine sounds. It’s pretty ghetto.
The one thing you will lose (besides the fake engine noise) is the active noise cancellation. So - the cab may be slightly louder when you drive,,,
pannwfn
Mississippi
2005 fx4 level II
Yes. It's called Courtesy Wipe and it can be disabled through the "productivity" menu in the Ranger.
Yeh you can disable that like he said. The only courtesy wipe I want is after ripping a big one just to check.
