FORScan Modifications
Andy
Andy
I was playing around with the button at lunch, I think this might be a case of needing to physically press the button to actuate a relay, no software involved. The reason I say that is that there is a clear delineation between folded and unfolded, there's a depressed and raised setting on the actual button. If I remember correctly in my Raptor, it was a momentary press of a button that triggered the fold or unfold. I hope I'm wrong though...
I was thinking the same.. if it’s not modulated by a bmc it could be just simply run off a relay. No complicated communication involved. Which would suck but it’s not a huge loss. Kinda betting the global danger conversion didn’t get a whole module/wiring makeover.
j0shm1lls
Josh
SoCal, USA
www.youtube.com
I was thinking the same.. if it’s not modulated by a control module it could be just simply run off a relay. No complicated communication involved. Which would suck but it’s not a huge loss. Kinda betting the global danger conversion didn’t get a whole module/wiring makeover.
It could lend to running a wire from the armed alarm out wire to the fold switch as a physical soultion... :sunglasses:
Andy
Andy
Yeah definitely the low tech work around hah.
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
Verified
Dark Car Mode (Police Option): 726-32-01 (2014+ MY) xxxx xXxx xxxx (BdyCM) 0 (Disabled - Default) 1 (Enabled)
720-04-01 (2015+ MY) xxxX xxxx xxxx (IPC) 0/1 (Disabled - Default) Note: Add a "4" to your stock value... i.e. 0=4, 1 = 5, 4/5 (Enabled)
Sound Location for Vehicle Chimes: 720-01-01 (2013+ MY) xxxx xxxX xxxx (IPC) 4 (Forwarded to ACM / Vehicle Speakers - Default) 0 (IPC Internal Speaker Only)
Note: IPC Only will NOT have automatic audio mute feature for chimes/warnings (Depending on firmware version)
Disable IPC Welcome Screen: 720-03-02 (2013+ MY) xxxX xxxx 4 (Disabled)
Note: No Blue Sky Background on IPC when getting into vehicle
Could not find ACM for fake engine noise. May not have it.
Verified
What does "dark car mode" do?
NateS415
Nate Schroeder
Cleveland, Ohio
Ford Ranger
From a quick google search I came up with this.
"All civilian models from Base to Sport have a feature called Illuminated Entry/Exit, where the cabin, parking, and puddle lights turn on whenever you enter/exit the vehicle. As a standard, Interceptors have this feature disabled by using a feature called "Dark Car," which disables the Illuminated Entry/Exit feature--police officers do not want to draw attention to themselves whenever the lights turn on as they enter/exit the vehicle."
I should know - google is your friend - google knows all. Thanks for looking it up - it makes perfect sense.
RCMUSTANG
Ray
Los Angeles
That is correct. I prefer not to have all those lights go on. Good thing is it's selectable.
j0shm1lls
Josh
SoCal, USA
www.youtube.com
j0shm1lls
Josh
SoCal, USA
www.youtube.com
RCMUSTANG
Ray
Los Angeles
Lariat 501a. Don't recall seeing a DSP module. But I wasn't looking for it.
RCMUSTANG
Ray
Los Angeles
I just downloaded it yesterday night.
j0shm1lls
Josh
SoCal, USA
www.youtube.com
Hmm, you're right - I just checked my AsBuilt backups, and there's no ACM nor DSP modules. This has to be a case of Forscan just not seeing the modules yet.
