FORScan Crowdsourced Wiki
Rene Michaels
SOLD IT
TX
How did you get to work so you can change that stupid double honk? I get to the tab for the modules but I don't have the 3rd tab I am seeing in the examples. I do have the temporary extended license but have not tried that yet. All I want to do is fix the double honk and add bambi mode.
I have this adapter (has CAN switch built in):
https://www.amazon.com/OBDLink-EX-F...t=&hvlocphy=9028226&hvtargid=pla-849940803002
I downloaded and installed FORScan version 2.3.29 beta for Windows listed at the top of this page https://forscan.org/download.html. Once installed, I purchased the 5-year license for $30 and activated my software.
This is the list of codes I used: https://docs.google.com/spreadsheet...iVSlDFGFHnfeuhb3RTMVz95730/edit#gid=815852466 Line #54 has the code to disable the double-honk.
Nutty 5.0
SE PA
2020 LB Super Crew, 2012 GT500, 2015 VW GSW TDI
Updated to the latest release .29 and still no go. Sent them a debug and they responded that they hope to add the 2020 (I understand that some 2020 owners are able to connect) soon and will send me a test build when they get to it.
Good news! They sent me 2.3.30 beta and working. Was able to make a few changes. Hoping this helps fellow FORSCAN’ers.
Rickfar
Central Pa. Harrisburg/Enola 17025
2019 supercrew sport
That is odd that the 2020 is different enough to require a new build. At least they are working on it.
I am looking for a spread sheet for my 2019 ranger that I can use for changing items with forscan.
I have looked and looked and I'm either missing it or I'm blind
There is no spreadsheet, but if you look at the first post in this thread you will see the values that have been done by other members to their Rangers that have been verified to work.
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
Tested a bunch of things. These are the ones that worked.
Enabled all the lamp outage on BCM configuration (Easy mode) IE Headlights (with or without fog lights), rear bulbs, LED Turn.
Power Point Timeout: Adjustable by seconds. BCM configuration
Enable Radio without Ignition Switch. Hit power button and the radio will turn on. BCM configuration
Adjust Radio without Ignition Switch PlayTime by minutes. BCM configuration
Enable Average Speed Display. IPC configuration
Enable Average RPM Display. IPC configuration
Can Change Instant MPG to Fuel Consumed Per Hour. IPC configuration
Can Change Vehicle Cluster Image from Truck (Utility) to SUV Icon
Enable or disable Seat Belt chimes for Driver, Mid Passenger, Passenger. IPC configuration
Enable or disable Chimes_Vehicle running with door open. IPC configuration
Let’s post here useful FORScan modifications for the 2019+ Ranger
In case you forget what the original setting was... Lookup Module Build Data (As-built) by VIN: https://www.motorcraftservice.com/AsBuilt
As of 5/11/2019 Much of this (not all)} is built into Forscan as "Service Procedures". You should no longer have to manually edit the asbuilt data as there should be easy to use menu options available.
OBDII ADAPTER: This is recomended as it was developed with the team at Forscan. https://www.amazon.com/gp/product/B081VQVD3F/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 (RCMUSTANG)
Disable Double Horn Honk - Cred j0shm1lls
Disable Front Turn Signal HyperBlink - Cred j0shm1lls
Disable Rear Turn Signal HyperBlink (XL Trim) - Cred j0shm1lls *unverified*
Bambi mode (AKA all forward lights or Six-High) - Cred RCMUSTANG
Dark Car Mode (Police Option) -Cred RCMUSTANG
RCMUSTANG
Sound Location for Vehicle Chimes
RCMUSTANG
Disable IPC Welcome Screen
RCMUSTANG
Disables three "doo-doo-doo" start-up chimes from cluster
Akshon
Disable auto start/stop
Specified Tire Pressure - Cred Arron
John Galt's Mods
Seat Belt Reminder Charm
Climate View on Lariat right side instrument screen (You cannot change climate only view for when sync screen is off)
Changing Sync3 Boot Screen
Note:There are others in the spreadsheet linked but I did not try them.
Secure Start (To idle car with key not in vehicle, cannot remove from park)
Power Point 1 second time (This will turn off power points after 1 second of turning off truck)
Navigation in Motion! Thank God! (911 assist will be disabled)
Speed limit sign will look European and FM radio stations will have and extra number like 102.70 instead of 102.7
Note:I did these on my Lariat Build Date 17JAN19. Please backup your setting first and proceed ONE AT A TIME with caution.
This is a link to the F150 Excel spreadsheet with all of their mods, its very thorough and technical, I have tried some not all obviously. Proceed with caution if venturing into the unknown.
https://docs.google.com/spreadsheets/d/1uDSQ1Z5a2Wt8-kjrSiVSlDFGFHnfeuhb3RTMVz95730/htmlview#
FX4 Off-Road Screen (Non-FX4 Models) - Cred WhiteLightning19
Note: the following options need forScan dated 5/11 or newer in order to get the non-as built options in the Configuration and Programming tab.
RCMUSTANG
Disabled AM/FM in Entertainment Screen
In IPC Module Configuration
RCMUSTANG
Enabled Parking Aid Front and Rear
RCMUSTANG
Chimes Vehicle Running Door Open Disabled
RCMUSTANG
Chimes-Primary Source IPC Speaker only
Arron
Frost Telltale (Below 5C)
In IPC Module configuration
Arron
Instantaneous Fuel Economy Numerical Gauge
Arron
Silent Mode Control Menu (Dark Car)
Arron
DTE (Distance to Empty) Sensitivity Menu
Arron
Intelligent 4WD Gauge
Intelligent 4WD Gauge Mode Feature
(Partially works (shows trail mode option selected) but does not show individual wheel response)
Modify behavior of alarm button on fob
Gfitzge2
Daytime Running lights Includes Parklamps
In BdyCM module configuration
Gfitzge2
Corner Light Mode for fog lights
RCMUSTANG
RCMUSTANG
RCMUSTANG
Enable Radio without Ignition Switch. BCM configuration
RCMUSTANG
RCMUSTANG
Enable Average Speed Display.IPC configuration
RCMUSTANG
RCMUSTANG
Can Change Instant MPG to Fuel Consumed Per Hour.IPC configuration
RCMUSTANG
RCMUSTANG
RCMUSTANG
NOTE: FOR INTERNATIONAL RANGER OWNERS. There are many differences with those models and what works with the North American version. This website can answer or has done many of the requests I've seen asked here. They are based on international Rangers. https://www.saeb.net/index.php
What is turn hyperblink? What is courtesy wipe? Did you know the Queen of England has an official ass wiper?
https://en.wikipedia.org/wiki/Groom_of_the_Stool
Dustanmont
Dustan
Oklahoma
Is anyone aware of a ForScan modification to keep the active gear screen up between all ignition cycles? I’m use to pressing the + button about 90% of the time, but I noticed my friends 2014 F150 3.5L always has it up. Maybe there’s a way to mimic the F150 code?
RCMUSTANG
Ray
Los Angeles
As stated before that's only through the pcm and a tuner. No one has unlocked that yet. I've been requesting since before I got the truck.
DHMag
Dale
San Antonio, TX
Hyperblink is when you replace the halogen turn lamps with LED. The lamp flashes normally but on the dash, it blinks twice as fast.
Courtesy wipe is when you use the windshield washer to clean the glass, the wipers does a courtesy wipe a few seconds after the wipers park to catch any trickles.
Thanks for that! Interesting...I replaced mine with LED and don't experience the fast blinking...also my wiper has always had this courtesy wipe...so I guess I don't have need for either:)
DHMag
Dale
San Antonio, TX
Or, if you're a dumbass like me and try to change the number of blinks in SCCM, you get hyperblink.
Dustanmont
Dustan
Oklahoma
so we can’t change the amount of auto blinker blinks like the F150s?
DHMag
Dale
San Antonio, TX
That is correct. I followed the f150 procedure and it created hyperblink. There may be a different way or more codes to change but I do not know them.
RCMUSTANG
RCMUSTANG
RCMUSTANG
RCMUSTANG
RCMUSTANG
RCMUSTANG
RCMUSTANG
RCMUSTANG
RCMUSTANG
RCMUSTANG
Where''s the mod code for these? Am I missing something?
