Madcow
- First Name
- Jason
- Joined
- Feb 15, 2022
- Threads
- 5
- Messages
- 24
- Reaction score
- 27
- Location
- Surprise, AZ
- Vehicle(s)
- 1997 Ranger XLT, 2022 Ranger Lariat Tremor
- Thread starter
- #1
So the new 22 Tremor arrived and I wanted to make some changes. A few items I looked at were already the way I wanted, so that was a surprise. For example, the fake engine noise was disabled by default.
ANC was disabled, though, and I wanted to see if this made a difference in the cab. I enabled ANC, but now the "doo doo doo" chime comes out of the instrument cluster rather than the audio speakers. I changed this back, but the chime still comes through the cluster. I didn't think the auto noise cancel had anything to do with the chimes... I'm confused now.
Before doing any of this, I loaded the AS BUILT data and saved it on my local drive. After the chime change I went to restore it, but it said no changes were made (basically no difference between the saved file on computer and the AS BUILT in forscan). How do I get the chimes to go back through audio system?
Did I break it?
I thought I was being good and backed things up, making one change at a time, etc, but the most dangerous actions come from when you think you know what you're doing, but really don't!
On another note, when looking at the IPC Module Config AS BUILT format, there are only 22 lines that can be changed (with hex). But looking at the regular IPC Module config there's a TON of items to choose from. I thought these two menus matched, i.e. making a change to the Mod config does the hex changes for you so you don't have to get into the code. Does this just mean there are more options in a module than are able to be modified with hex?
Anyway, I thought I looked before I leaped...
Any ideas?
Thanks!
JJ
Did I break it?
Any ideas?
Thanks!
JJ
