DFisher
- Thread starter
- #1
There are a couple things I would like to tweak but aren't sure if FORScan is the right place. Hoping someone can tell me if FORScan is the tool for the job.
1) When in drive (D), if you push + once on the gear selector it displays the transmission gear scale on the dashboard display. This goes away every time the vehicle is started .Can something be tweaked so that it displays all the time?
2) HVAC fan speed. When using the HVAC on AUTO I feel the fan speeds are always too slow. I usually have to bump up the fan speed 2 or 3 times to get enough air movement. Can I modify the setting so that the fan speeds are greater with using AUTO?
Thanks,
Thanks,
