That guy
- Joined
- Jul 30, 2023
- Threads
- 3
- Messages
- 11
- Reaction score
- 28
- Location
- CALGARY, AB
- Vehicle(s)
- 2021 ranger tremor
- Thread starter
- #1
Hello everyone, maybe there is shudder fix on the horizon?
I experienced a shudder at 30km/hr like most folks on the forum by the sounds of it. It didn't really bother me as putting the truck in S instead of D helped the symptoms. I also had the clunk when stopping. I took it to a Ford dealership, asked them to re-grease the slip yolk (its under warranty so why would I do this). They took it for a test drive, told me they felt the shudder, and said they would like to try a TSB to correct it, they also said it may help with the clunk.
They performed the TSB Shim, it fixed the shudder for 1 day then returned and shuddered at 30, 50, 80km/hr. Again, driving in S seems to help. The truck still clunked with stopping.
Took it back, told them it was worse. They had it for a few days, they drove other non-tremor rangers around, and consulted with Ford. Their outcome was that it was present with the other fords on the lot, Ford said it was normal thus there is nothing more they could do. I told them to remove the TSB, and put it back to stock. They also stated that they were unable to grease the slip joint. They said that if they pull apart the drive shaft and re-grease, it will void the warranty on the driveshaft. Has anyone else been told that by the dealership??
They phoned back, the dealership said that Ford followed up and said that they want to put my truck on a trial... their new fix is to remove the tremor drive shaft and install a new flange and a drive shaft that has a Ujoint opposed to a CV joint.
I was confused what this would actually do, I had a meeting with the mechanic and the service manager at the dealership. they reassured me that if it doesn't help or fix the shudder it could be undone, re-shimmed to stock and have the Tremor drive shaft put back in. The service manager said that Ford may have changed the drive shaft since they called it a trial...
From what I read there are more benefits to a CV than Ujoint, any thoughts?
I am currently waiting for a phone call to have it the drive shaft swapped out. I will update with the results in later days.
Cheers,
Cheers,
