Ford Performance Tune - Update
Rp930
Rp930
Denver
Thanks. Makes me wonder what the changes were from 2020 that warrants the delay. Or is it just red tape? Was there a similar delay from 19 to 20?
Probably had to recertify 2021 the EPA is a very small group. Takes time.
Vitis805
Santa Barbara County, CA
2019 Ranger XL
Wine Nerd
I know nobody asked but I'm going to give an initial review of my experience with the new FPP tune update in comparison to the first FPP tune. After ~50 miles of my typical route:
Truck feels less snappy off the line, and about the same when doing a rolling WOT punch.
Initial transmission feel was lots of bucking and hard shifts, but has smoothed out considerably and does not seem to hold gears nearly as long.
MPG seems to be slightly down, but could be due to the tranny re-learn or many other factors (fuel, air temp, barometric pressure, etc)
I suspect that the change was mostly lowering boost pressure, and restricting the tranny shift points to a certain rpm. AFRs probably aren't as lean also which would explain the loss of snap off the line and the MPG decrease. Doing all of these things means safer temperatures during towing operations.
I do tow often enough that I might just keep this tune on, but it is so easy to flash over I wonder if Ford Performance would let me have my old tune back if I desired? I might send an email to see. It would be nice to have both IMO.
Rp930
Rp930
Denver
My experience is almost the opposite. I think it has more grunt in the low to mid range and seems to skip gears a lot less. It seems more responsive in traffic and seems to downshift quicker. Initially I thought it shifted up too soon but as the transmission has learned it feels better than before. I guess more people will weigh in. The more I drive it the more I like it.
pull string get cookies
Justin
Minnesota
2019 Ford Ranger Lariat FX4 White Platinum
Thanks to you both for sharing your experiences with the updated tune. As I rarely tow, I'll wait a bit to see what the general consensus is on the update before installing. Almost rushed right into it, thanks again!
Vitis805
2019 Ranger XL
Wine Nerd
I know, I found that peculiar. I was expecting the changes that you had mentioned but kept experiencing the opposite. My low end seems to be less than before (I could chirp at any stop if not careful) and now seems to take a bit of an effort to chirp. I also travel a grade that would hold the tranny at some gear (XL trim, no read out, so I'd be guessing) @ around 4k RPM at 69 MPH unloaded, and now it upshifts long before that. This is all in D, I haven't done the route back and forth in S yet.
I will drive it at least 2k to decide if I like it more or less.
Justin
Minnesota
HoosierRanger
Matt
Indiana
2019 Ford Ranger Lariat Fx4
Snow3d
2021 Ranger Lariat, 2007 Subaru Forester XT
Human
Definitely a bummer that the tune isn't ready yet for the 21's.
Rp930
Rp930
Denver
Would be interesting to see a badk to back dyno run of old and new.
Blmpkn
Maine
2010 ranger
In D, if you hit the "shift up" button it will toggle the gear display in the center screen.
Bor
CT
2020 Ranger
So far it looks like we have one thumbs up and one thumbs down for the updated tune. Did Anyone else try it and what do you think?
NNayak
Neel
Los Angeles
2019 Ranger Lariat RTR
Aerospace Engineer
I updated my tune, verified that the file ID changed in the ProCal app on my PC, and flashed the update to my truck. After updating, I can't say I've noticed any huge differences in power or drivability -- both remain greatly improved over the stock calibration. It was worth the 30mins of work for the peace of mind provided by knowing that the tune is compatible with towing.
Bor
CT
2020 Ranger
Bump. Any more feedback on the updated tune ?
