Ford licensed TBC Install Instructions
Gixxers
Joshua
2020 ranger
Steelworkers
Just had mine installed works great, only problem was dealer scratch the hell out of the side of my ride and broke the interior trim.
DanaBovender
Dana
From the Florida Panhandle Residing in Germany
2019 Ranger Lariat Supercrew 4x4
Gov Employee
Well I received mine today and it’s definitely different than the other Redarc. Cable is a different plug and looks shorter than the others that I have read about. Knob is different too, it now has a trailer logo on it and thanks to Ford for not even assuring that the rubber cap is oriented properly.
My OCD made me have to fix it and make sure at zero the trailer logo is level. Had to pry off the cap and then re-glue it on in the correct orientation. WTF?
They give you the older Redarc plate with the two holes (1 for the controller and 1 for the led) and the old installation information but the new control does not have the additional little led? WTF? And the installation guide tells you to drill both holes still. Again.....WTF?
I guess I will see how it goes tomorrow, fortunately it’s not too hot out yet so I am planning a full day just to make sure that I am not rushed.
t4thfavor
Chance
Well, considering that they entirely forgot about the necessity of a brake controller for the first 6 months of sales, this doesn't seem too far from "normal".
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
I mean, depending on where it was level at before, you probably will *never* reasonably operate/leave that knob at 0. Turning the brake bias to 0, turning off the brakes, defeats the purpose of having it in the first place.
But yes, the instructions always leave a bit to be desired.
DanaBovender
Dana
Gov Employee
my intent is to have it turned off/at zero when not towing. My OCD just couldn't take it
Reactions: EJH
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Understandable. WIth no trailer connected though, it's not really "on" - 0 doesn't actually *disable* the controller, it's still powered, it's the trailer signal that controls whether or not it's powered.
DanaBovender
Dana
Gov Employee
Okay so this was not nearly as bad as I thought, only took me 3 hours from start to finish.
I just need to calibrate the unit when I get a chance.
Having all the correct tools and not being rushed is the key.
Those two wires under the dash are not fun to get at and get stripped, thankfully I have a quality front loading wire stripping tool and it wasn’t too bad. Took a few tries before it was able to get a clean strip.
All in all I am happy that I did this myself and didn’t break any clips at all.
Just take your time and it’s not that bad.
Shomare
Bill
Fayetteville NY
2019 XLT
Union President
IMO, if you order the trailer tow package and the truck is rated for 7000 lbs, this should have come with that package or be plug and play.
DanaBovender
Dana
Gov Employee
Well you I and about 25K more people agree, but we’re currently SOL.
I for one don’t think we can change that, so I did what I needed to do to prepare for the next few years.
Shomare
Bill
Fayetteville NY
2019 XLT
Union President
I hear you. Gotta do what you gotta do.
LHC
Hank
Philadelphia pa
2020 Ranger XL
OK, yesterday I picked up my new '19 Ranger.
Today I ordered the TBC kit (from Levittown) and spent quite some time reviewing the install document posted here earlier.
(BTW, wifey is apoplectic over me "tearing up my brand new truck" to install the TBC--women, sheesh!)
Basically you install a Redarc Tow-Pro Elite and then 'add in' a Lumen 'Trailer Lamp ECU'. The latter sends six wires back to the CHMSL (Center High-Mount Stop Light) where you disconnect the three-pin connector that is feeding it and jumper in the wires from the front based on which color connectors Ford used at the factory.
'Why this lunacy?', you ask. Well, the reason is because the CHMSL is a very special kind of brake lamp. Since Ford failed to think about an integrated TBC in time, they had to work out this Rube-Goldberg solution to provide a fully integrated, factory-look install that would meet all of DOT's very complex rules when it comes to automated systems in autos (AEB & FCWS). Everything is plug-and-play with the exception of two wires that have to be spliced--but those two wires were meant to be spliced as they are terminated and hanging loose behind the trim panel.
So, once you jump through the hoops of installing the fool thing, you have a 'factory installed look' as well as what many are calling the most advanced TBC out there, the Redarc Tow-Pro Elite AND it plays well with your AEB and FCWS!
You have to admit that one little knob/button that blinks different colors and has sense enough to control your trailer for you trumps the huge "squeeze me' paddles on the older integrated systems.
I'll report back after I 'tear up my interior' and y'all will want to know if divorce happened.
McDeuce
2021 Ranger Lariat Tremor
My local dealer said if I buy it from them at list price, they will install it for $75. I am just going to go with it. Not worth the risks to me.
WLFPIR8
Ethan
Central Ohio
whor.us
2019 Ranger Lariat FX4/Sport in Saber Orange
Systems engineer by day, maker and multimedia guru by night.
That's a pretty good deal. It's def more than a $75 pain to install it yourself.
Cabose-1
Eli
Student
Mo
This popped up on my YouTube feed the other day (not really sure why as I haven’t even been in the market for a TBC), but figured maybe it’s worth a watch for some of you trying to do an install. He talks about installing on a Ranger without the factory tow package installed and the differences. Also has some other good info for trucks with the factory tow package and why it might not be a good idea to splice into the brake wire from the brake peddle.
Sorry if it’s already been posted...
Mother fucker. Wow. I really need to find someone knowledgeable to install mine. Really knowledgeable
Cabose-1
Eli
Student
The dealer guys worry me. They do the shirt cuts like connecting to the switch and so on. They don't know specifically about the issue in the video, they just work where they can get a job. Many dont know about cars they just know how to work on cars. So now after the video i understand the importance of the center high mounted brake light. Only because i researched it. The ford guys have to work on every ford car out there so they are only familiar with common problems. They are not dumb or stupid (lazy some of them), but it is just impossible to know in every detail every ford make model and trim level. Not with the modern day turnover rates on mechanics
