Flowmaster Delta Boost?
livetoski78
Douglassville, PA
2022 Ranger XLT, 2020 Explorer ST
Software Engineer, EMT, Amateur Rocket Scientist
Has anyone here tried the Flowmaster Delta Boost on their G5 Ranger? It essentially just re-writes the output from the boost sensor to one of 4 settings to trick the computer into thinking it has more or less boost. It's kind of a hack, but it's bolt-on and easily removable. I would just watch for a lean condition if running the +2 or +4 psi mode. I'm more interested in the valet mode, which deducts 4 psi. I'm thinking it might be beneficial for gas mileage and commuting when I don't want or need ridiculous power.
I have this one https://www.holley.com/products/tun...ng_modules/flowmaster_delta_boost/parts/18102 that I had picked up for my 2016 Escape a couple of years ago, but never installed. I'm curious if it will work with the Ranger that I'll be getting any day now. It fits the Focus 2.0L and 2.3L engines, so I'm thinking it might, but am looking for someone to confirm. It seems like it just needs to match the sensor connectors since it goes in-line with the boost sensor coming off of the intercooler. Anyone?
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
Well this looks neat as heck.
If you have one, plug it in!
livetoski78
Douglassville, PA
I'm hoping to take delivery on the truck by the end of this week. It's on a train somewhere between Michigan and Pennsylvania! It's definitely not a replacement for a proper tune, but like I said, with a 1.5 hour commute into Philadelphia for work, the potential gas savings with the valet setting are not insignificant! There is another model with different connectors (Model # 18101) which worked with other 2.0/2.3 Ecoboost engines of that era. I'm hoping it's not those connectors! Since our engine is a descendent of the Focus RS, I'm thinking the one I have is the better bet. I'll be sure to post my results.
Can't say if it will work but I would be careful of things like that. Being a piggyback type unit and essentially lieing to the PCM engine damage may result.
livetoski78
Douglassville, PA
Well, yeah...anytime you run more boost, you run the risk of running lean. Which is why I'm not going to run more boost with it...at least until I get an A/F ratio gauge or plug into the ECU with a scanner so that I can measure it. I've been overboosting and tuning turbo engines a long time. I had a 1988 Shelby Z in college that was a lot of fun! Anyone here familiar with the Grainger valve boost controller? ;)
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
If this thing works it could Supplement a tune
Still not a great idea. Lets just say the said tune installed has increased boost to a safe limit where you shouldnt go any higher. But then you decide to increase the boost again with this piggyback unit. What do you think is going to happen? I can tell you but I think you already know the answer to that one
livetoski78
Douglassville, PA
This is definitely a use it or tune it device. I wouldn't do both. Like I said originally, however, I like it better for the ability to neuter the boost for commuting. Less boost = less fuel...more or less.
Agreed but also understand that if you arent getting into it you arent using as much fuel anyway. Turbochargers are way more efficient compared to supercharger and naturally aspirated engines and that is the main reason why Ford is doing so many EcoBoost engines. Also any on here(myself included) have increase the Fuel mileage with a tune. Will the flow master module do that? I doubt it. But it's your call.
AZRanger
Lane
Arizona
2021 Ranger XLT FX4
I fix Pink jeeps
1.5 hour one way?!? Sheesh
livetoski78
Douglassville, PA
Well, if it works, it's an interesting experiment. I really don't want to tune a brand new truck and void my warranty. If I do, I'll be getting the Ford Performance tune...backed by Ford. Although, I was just reading about the towing BS. That sucks, because one of the reasons I went with the Ranger over the cheaper (and better gas mileage) Maverick was the towing capability.
amick1995
Alex
CO
2021 Ranger Lariat Trenor
they updated the tune a while back to help with towing.
